gearing question - JeepForum.com
post #1 of 13 Old 02-23-2008, 02:09 PM Thread Starter
bigdog79
gearing question
just bought a 98 tj 5 speed and need to find out the stock gearing any suggestions where to find out?
bigdog79 is offline
post #2 of 13 Old 02-23-2008, 04:30 PM
Rocky529
Rocky529's Avatar
Rear differential cover there will be a tag... 9 o'clock position.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 13 Old 02-23-2008, 04:32 PM
htownjeep
What's that noise?
htownjeep's Avatar
If the tag is gone get a build sheet from Jeep.
Drink upstream from the herd.
htownjeep is offline
post #4 of 13 Old 02-23-2008, 04:33 PM
McLovin
if it's a manual stock gears will be 4.10's. Auto it will be 3.73's.
I have 4 new zone hydro shocks for sale...PM for a price.
McLovin is offline
post #5 of 13 Old 02-23-2008, 04:35 PM
htownjeep
What's that noise?
htownjeep's Avatar
This is false. These are possibilities, but not the only ones.
post #6 of 13 Old 02-23-2008, 06:16 PM
McLovin
No it's not, the 2.5L left the factory with only those gearing options. Sure someone could have swapped axles, but thats highly unlikely.
McLovin is offline
post #7 of 13 Old 02-23-2008, 06:37 PM
Waldn
And to fill out the rest of your profile
trans = AX5
TC = NP231
FA = D30
RA = D35
Gears = 4.10
unless some messed with the stock stuff which isn't likely.
97 TJ SE 2.5L Auto, 3" BDS, 255/85-16 BFG MT KM
04 KJ LTD Frankenlifted, Full Mopar Armor, front reciever hitch for winch, Rubicon Moabs and MTRs
Waldn is offline
post #8 of 13 Old 02-23-2008, 06:37 PM
htownjeep
What's that noise?
htownjeep's Avatar
Where does it say it was a 2.5L? His question just says it was a 98 TJ 5speed.
post #9 of 13 Old 02-23-2008, 06:38 PM
Waldn
In his profile
Waldn is offline
post #10 of 13 Old 02-23-2008, 06:44 PM
McLovin
Thats why I read his profile
McLovin is offline
post #11 of 13 Old 02-23-2008, 06:49 PM Thread Starter
bigdog79
thankyou for taking the time to answer my question i have only been a member of JF for 2 days and i have already figured out that the jeep community has no problem sharing the advice and expierence that you all have to help a newcomer you guys aare great
bigdog79 is offline
post #12 of 13 Old 02-23-2008, 06:53 PM
htownjeep
What's that noise?
htownjeep's Avatar
Originally Posted by Waldn View Post
In his profile
Gotcha...didn't read profile obviously.
post #13 of 13 Old 02-23-2008, 07:19 PM
AZTJ02
Taken from this thread: http://www.jeepforum.com/forum/showt...threadid=23792
The easiest way to determine your gear ratio is to check the tag that's bolted to the front differential cover. On the tag you should see some numbering such as 3.54 or 3.73, either of those numbers would indicate the stock axle ratio. To verify this (your gears could've been changed,. wrong tag, etc.), jack up the rear axle and support it with jack stands. With the transmission in neutral, rotate the rear driveshaft by hand. Count the number of driveshaft revolutions required for one revolution of the tire.
If the driveshaft turns approximately 3-1/2 times, you have a 3.54 ratio, etc. It's helpful to use a grease pencil or chalk to make a reference point on both the tire and driveshaft. For increased accuracy it is recommended to rotate the wheels two times and divide the result by two.
2002 TJ Sport
HCR
AZVJC
AZTJ02 is offline
AX-15 Gearing Question mean90yj YJ Wrangler Technical Forum 5 01-30-2007 08:28 PM
Another re-gearing question sryan2k1 TJ Wrangler Technical Forum 6 12-11-2006 11:31 AM
Gearing question. muddy tj TJ Wrangler Technical Forum 4 07-09-2006 12:30 PM
Re-Gearing Question soontobeinsand TJ Wrangler Technical Forum 35 08-18-2005 11:14 AM
Gearing Question Geaux555 TJ Wrangler Technical Forum 1 09-25-2003 09:08 AM
