Gearing Question - JeepForum.com
post #1 of 8 Old 01-21-2008, 11:00 PM Thread Starter
Cwill15
Gearing Question
I'm new to the Jeep community and look forward to getting into it all. My question is, On a 99 Wrangler with a 4.0l and stock gears. I want to get a lift to fit atleast 33x12.50 if not 34's or 35's. With which tire size would it be absolutly ness. to change out the stock diff. gearing?
Thanks in advance guys.
Cwill15 is offline
post #2 of 8 Old 01-21-2008, 11:12 PM
Rocky529
Rocky529's Avatar
It depends what your current gearing is and what kind of transmission you have.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 8 Old 01-21-2008, 11:16 PM Thread Starter
Cwill15
Not too sure on the stock gearing but it's an auto.
Cwill15 is offline
post #4 of 8 Old 01-21-2008, 11:35 PM
Rocky529
Rocky529's Avatar
Well, look at your rear differential at the 9 o'clock position and you'll see either 3 07 or 3 73. you can tolerate 33s with 3.73... if you have 3.07 it'll drag but you can live with it. So on and so forth, find out your stock gearing.
Rocky529 is offline
post #5 of 8 Old 01-22-2008, 04:13 PM
joemomma4040
Regearing is expensive I lifted my 97 tj and put 33x12.5 r15 on and I noticed it a little draggy especially on the highway in fifth gear It was suggested to me to put on a throttle body spacer and cold air intake, it is my next mod as soon as I have enough money others I know have done it and are very pleased with the boost in power hope this helps
joemomma4040 is offline
post #6 of 8 Old 01-22-2008, 04:19 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your automatic is a 3-speed without an overdrive so don't gear too low or your highway RPMs will be too high. If it were me, I would go 4.10 with 33" tires and 35" tires would do well with 4.56 with your particular transmission.
It costs, on the average, $1200 or so to regear both axles including all parts and labor.
Gone on vacation until August 25.
Jerry Bransford is offline
post #7 of 8 Old 01-22-2008, 04:39 PM
97casteeltj
97casteeltj's Avatar
my mechanic will regear my axles for 125 bucks each!
needing a new rig....
97casteeltj is offline
post #8 of 8 Old 01-22-2008, 04:47 PM
Jerry Bransford
Administrator
Great, make darned sure to buy your gears through him too so if anything goes wrong after the installation, he will take care of it with no questions asked.
AX-15 Gearing Question mean90yj YJ Wrangler Technical Forum 5 01-30-2007 08:28 PM
Another re-gearing question sryan2k1 TJ Wrangler Technical Forum 6 12-11-2006 11:31 AM
Gearing question. muddy tj TJ Wrangler Technical Forum 4 07-09-2006 12:30 PM
Re-Gearing Question soontobeinsand TJ Wrangler Technical Forum 35 08-18-2005 11:14 AM
Gearing Question Geaux555 TJ Wrangler Technical Forum 1 09-25-2003 09:08 AM
