Quantcast Gearing Question - JeepForum.com
Truck-Lite 7" Round Headlamp Giveaway! - Drive OffRoad Gift Certificate Contest!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Gearing Question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSwag Off Road BIG-HIT TJ-YJ Rear BumperNEW Fawkes modular recovery & bull bar mounts for WJs.
Unread 01-29-2007, 05:42 PM   #1
ITCS_USN_RET
Gearing Question
I know where to look but am having a hell of a time reading it. Remember once seeing someone check by VIN.
If possible could you look up 1J4FA39S54P703422
tks
ITCS_USN_RET is offline   Reply With Quote
Unread 01-29-2007, 05:43 PM   #2
Rocky529
Jeep
Rocky529's Avatar
You can send that to DC and request a build sheet, otherwise we can't do much with that. You can also go out to your Jeep and look at the rear differential, in the 9 o'clock position... it will either say 3 07 or 3 73.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Unread 01-29-2007, 05:50 PM   #3
SecondTJ
if you can't read it, the build sheet is...
http://www.jeep.com/wccsapp/universal/J/index.jsp?appStr=wccs&titleStr=Contact+Jeep&family Str=brand&franchise=J&actionURL=%2Fwccs%2Fbrand_fo rms%2Fus%2Fwebform.jsp&promotion=null&category=U
'00 Sport. 5-speed, Detroit TrueTrac Dana 44 rear, Detroit TrueTrac front, 4.10's, 2" RE BB, OME shocks, 31" BFG MT, JKS Quicker Disco's, Borla
'99 Z28 M6, some goodies
'94 'Vette, A4 all stock
SecondTJ is offline   Reply With Quote
Unread 01-29-2007, 05:52 PM   #4
ITCS_USN_RET
when you look at the differential is the first 3 spaced a little from teh other 2 numbers. Mine is very hard to read but I think it reads 3 then a few spaces - then 73 together. My be wishful thinking though?
Unread 01-29-2007, 05:54 PM   #5
SecondTJ
Its not going to have the numbers together ( say 3.73 or 3.07) it will say 3 (space) 73, or 3 (space) 07.
Unread 01-29-2007, 05:56 PM   #6
Rocky529
Jeep
Rocky529's Avatar
Most likely 3.73 gearing with the Dana 35 rear.
Unread 01-29-2007, 05:56 PM   #7
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Here's the tag you need to look at. As you can see in the below photo, the axle that tag is bolted to has a 3.73 ratio.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 01-29-2007, 05:57 PM   #8
ITCS_USN_RET
OK. Tks for the info. I sent my request to DC.
If it is 3 73 vice 3 07 - does that make a considerable difference on 32" tires. Many have stated 3 07 suck with 32's....hows 3 73 in comparision?
Unread 01-29-2007, 05:59 PM   #9
ITCS_USN_RET
Mine looks like ***** compared to that tag - but I'm pretty sure its 3.73. Thanks for the PM as well earlier - trying to get all my facts straight before I spend the $$$.
Unread 01-29-2007, 06:01 PM   #10
SecondTJ
Yes it will make a big difference on 32s, if you have the 3.73s you will be much better off than 3.07s
