Gearing Help, 33" tires, automatic - JeepForum.com
post #1 of 9 Old 07-01-2010, 02:52 PM Thread Starter
unbreakable
I have a 97 tj with a 4" lift and 33" tires, 4.0 automatic' D35. I need some advice on what gears to go to in order to get some power back. This is my daily driver and I do not off road it. thanks for some help.
unbreakable is offline
post #2 of 9 Old 07-01-2010, 04:40 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Since you don't offroad (yet) and this is for street/highway use, I'd go with 4.10 for 33" tires and your 3-speed automatic. Even if you start offroading 4.10 will still be a good ratio for your particular transmission.
Jerry Bransford is offline
post #3 of 9 Old 07-01-2010, 04:51 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
wow, i just noticed your user name... and the D35... wow. good for you.
gearing is a tough choice. you only want to do it once and be done with it. are you POSITIVE you are not going to step up to 35s EVER?
4.10s, just like JB said. otherwise 4.56. good luck.
Mail crawling.
MisfitSeven is offline
post #4 of 9 Old 07-01-2010, 05:04 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
4.10 or 4.56.
I prefer 4.56 for the little extra low end power.
With 4.56, RPM will be about 3,500 at 70 MPH.
If you are not comfortable with that, 4.10 would be a better choice for you.
Wheelin98TJ is offline
post #5 of 9 Old 07-01-2010, 05:53 PM
Farmkid
I have a 97 tj Auto w/35's and 4.10. I love it. Perfect set-up for me
Farmkid is offline
post #6 of 9 Old 07-01-2010, 11:21 PM Thread Starter
unbreakable
Thanks guys. Now what all am I looking at replacing to regear to 410? Is this something I can do myself? Can someone point me in the right direction bc I am curious at cost and parts. thanks again
post #7 of 9 Old 07-02-2010, 05:31 AM
NotURMailman
NotURMailman's Avatar
You may come out cheaper if you can find a set of used stock D30/D35 axles out of a 4 cylinder TJ and swap both entire axles. Then you could sell yours and get some oney back. The 4 cylinders came with 4.10s.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #8 of 9 Old 07-02-2010, 09:32 AM
Jerry Bransford
Administrator
Not really unless you are willing to buy the special tools and are willing to spend time to learn how to do it right. It's a very tedious and exacting procedure to properly set up the relationship between the ring & pinion gears and if not done perfectly, the new gears will be ruined in short order.
It'd such a demanding job that if you go to a 4x4 shop with say 6 mechanics, odds are that only one or two will be trusted well enough to do their ring & pinion installations.
post #9 of 9 Old 07-02-2010, 04:07 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Thay also came with 3:73 and 4:56 gears...
Knuckelhead is offline
gear , regear , automatic , 33 , tires
37" tires with 4.56 gearing on an automatic? BradinFLA JK Wrangler Technical Forum 13 12-04-2009 06:14 PM
2006 4.0 Automatic TJ re-gearing? vix TJ Wrangler Technical Forum 16 04-10-2009 10:03 AM
Gearing An Automatic lecharbon TJ Wrangler Technical Forum 1 04-28-2008 08:39 PM
2.4 automatic gearing questions sijeep TJ Wrangler Technical Forum 11 11-05-2007 08:48 PM
Does automatic in tj make a difference when re-gearing Scott B TJ Wrangler Technical Forum 7 04-06-2004 08:13 PM
