Gearing for 33s w/ auto & Axle Swap Question - JeepForum.com
post #1 of 6 Old 08-15-2005, 11:27 AM Thread Starter
matty427
Hey Everyone - Every gearing chart I see is for a manual transmission. I have an 03 sahara lifted up with 33" tires and an automatic transmission. What do you think I should gear to? From what I can gather 4.11 seems optimal but I wanted to get some second opinions.
A friend is offering an axle swap. He has a 97 4 cylinder engine and is regearing to 4.88 I think. The plan was to take my axles and regear them and I take his with the 4.11s already installed. We both have Dana 30/35s. Is there any difference between the axles that I should be hesitant about? The only thing that I am wary of is going to axles that are 6 years older than my current ones.
matty427 is offline
post #2 of 6 Old 08-15-2005, 12:11 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I'd rather have 4.56, especially since you have the 4 spd auto w/ OD.
For the right price, I'd consider 4.10.
Wheelin98TJ is offline
post #3 of 6 Old 08-15-2005, 12:21 PM
skoke70
With the 4 speed auto with 33" tires I would go with 411. The 456 would be great if you every wanted to put 35" tires but might be a little to much rev's with 33" tires.
skoke70 is offline
post #4 of 6 Old 08-15-2005, 12:34 PM Thread Starter
matty427
Thanks for the input. The price is right so I am probably going to go for it. I am planning on going to 35s in the future (distant future!) but along with that i will probably swap up to the dana 44 and lock it. That's when I can step up to 456/488
matty427 is offline
post #5 of 6 Old 08-15-2005, 12:47 PM
Av Native
I have a 5 spd with the 4:10 gears and mine is a daily driver and am totally happy with it, (Same size tires) so you should be really happy with that gearing with a auto..
04 Silver TJ
4" rough country lift
1" currie MML/BL
JC fab rockers and 1" seat lift
33"BFG MT's
Nth degree adjustable upper arm
Nth degree lower arms
Power trax front locker
Av Native is offline
post #6 of 6 Old 08-15-2005, 02:12 PM
pismo61
pismo61's Avatar
2015 JK Wrangler
Ive have 4.56s in mine 2500 rpm at 70 with OD on. Perfect with my 32s(tires).
2015 Red 2 Door(half) 6sp.
pismo61 is offline
Best axle gearing for 32 with auto 32rh Alberto4x4 TJ Wrangler Technical Forum 5 03-15-2009 05:35 PM
Gearing Question for 4 Speed Auto steelhd1 TJ Wrangler Technical Forum 52 02-15-2009 11:53 AM
Axle swap-- what gearing should I go with? pmccoy9876 TJ Wrangler Technical Forum 13 11-26-2008 05:11 PM
AUTO Gearing question YellowTJ06 TJ Wrangler Technical Forum 9 06-28-2007 07:12 AM
Axle gearing question for 4 spd auto FanAholic TJ Wrangler Technical Forum 3 09-14-2006 01:46 PM
