Gearing for 05 Rubicon unlimited and 35's - JeepForum.com
post #1 of 18 Old 07-31-2012, 01:33 PM Thread Starter
borkap
Ok I have read a couple of these threads but I am seeing conflicting information. I have a 2005 Wrangler Unlimited Rubicon 6 spd manual on 35's and it is in need of regearing. Its not a daily driver but I drive it to spots to wheel as far as 9 hours away so highway manners are at least somewhat important to me. My goals are:
Slow down 4 low 1st gear
Better take off
Better mileage (Pipedream)
What should I put in it?
Friends don't let friends chrome out their rig...
borkap is offline
post #2 of 18 Old 07-31-2012, 01:47 PM
TheBoogieman
Still disturbed
TheBoogieman's Avatar
I'd go with 4.88's.
TheBoogieman is offline
post #3 of 18 Old 07-31-2012, 02:23 PM Thread Starter
borkap
Yea I'm between that and the 4.56s. At the moment I'm leaning toward the 4.88s.
borkap is offline
post #4 of 18 Old 07-31-2012, 02:29 PM
Marauder_Pilot
Marauder_Pilot's Avatar
I dunno, with long highway drives between you and your trailheads, I'd go with the 4.56.
Trail and city only, 4.88 all the way, but that's a little tall for a 9-hour drive.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2006 Ford F-250-Stock
Marauder_Pilot is offline
post #5 of 18 Old 07-31-2012, 02:41 PM
billy_butler
if you take it easy on the trail 4.56... you are going to get better hwy manners with the 4.56 and you wont notice that big of a dif with the rubicon transfer case. if you wheel hard and ever want bigger tires (which you might) get the 4.88s. i run 4.88s with 35s and a 231j tc and i can start out in 3rd in 2wd bro. i have not used 1st gear in 2wd since i got them. they are amazing on the trail. but, if you are worried about highway manners at all get the 4.56s. it really does not matter what you get tho cause you will want the other once you get it. its just human nature.
billy_butler is offline
post #6 of 18 Old 07-31-2012, 02:43 PM
billy_butler
here is a gear chart man.
http://www.superlift.com/library/gears.asp
post #7 of 18 Old 07-31-2012, 03:00 PM
Fingers302
I like mine better with stock gearing after going up to 35 inch tires. 4.10s and 31 inch tires was wayyy too low gearing. With the bigger tires, it runs about 2500 for 70 mph. I now use 1st gear (high range) to start off. When it was stock, I'd take off in 2nd, then 4th, then 6th gear, skipping all the rest. Now 6th is like overdrive. But OP said he didnt like it like this, so.....I'm wasting his time. Sorry.
Fingers
06 LJ Rubicon, not stock
83 CJ 7, all stock
84 CJ7, dang near stock - Daily Driver!
Fingers302 is offline
post #8 of 18 Old 07-31-2012, 03:32 PM Thread Starter
borkap
Now I am thinking 4.56s I will likely keep the 35s for at least a year or two. the 4.56s should still be a dramatic improvment over stock and still maintain drivability so they make sense.
borkap is offline
post #9 of 18 Old 07-31-2012, 03:43 PM Thread Starter
borkap
Now what to buy to do this? I havent done the swap before but I had never rebuilt a motor before the first time I did it either... I'm open to recomendations. I don't mind spending a little more for better quality within reason.
borkap is offline
post #10 of 18 Old 07-31-2012, 04:43 PM
Marauder_Pilot
Gears are the one job you want to leave to a shop, to be honest.
If you look, there are plenty of guides that show you how, and I'd try on a trail toy, but the slightest mistake can grenade your diff. Not something I'd want to risk on a highway vehicle.
-TTAC
post #11 of 18 Old 07-31-2012, 05:00 PM
billy_butler
this is a very true statement, i tried to do my own and the first set did not work out so well, but the second set has been running like a champ, i just eyeballed mine in the driveway... i am however, not very confident in the integrity of it-as i would be if it was done by a shop with all the right tools...
post #12 of 18 Old 07-31-2012, 05:50 PM
flying_bosun
It's very different from rebuilding an engine, and while I applaud the confidence and can-do attitude and generally avoid discouraging DIY efforts, this is one of those things best left to someone who has the tools and experience to be able to do it in their sleep, IMO. In case it's not been mentioned, be sure to have him (her? ) get all the parts, too, so that there can be no finger pointing of something doesn't go well.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #13 of 18 Old 07-31-2012, 10:22 PM Thread Starter
borkap
Wow so I went from ~800 total to 2500 total by the local shops estimte...
borkap is offline
post #14 of 18 Old 07-31-2012, 10:31 PM
Jeepin72
With the NSG370 and 35's you will like the 4.88's. I highway cruise at 75 in 6th gear. I don't use first unless I'm off road.
Jeepin72 is offline
post #15 of 18 Old 07-31-2012, 10:54 PM
alex211
1995 XJ Cherokee
I would go with 4.88s
I have 4.88s with 33s and a 5 speed, perfect right now but when I step up to 35s or 37s I'm gonna be wishing for deeper gears again.
95 xj bone stock for now
alex211 is offline
gearing , rubicon , tj
Short arm lift for 2005 Unlimited Rubicon ....OME or Rubicon Express which manufactur Rubi Unlimited TJ Wrangler Technical Forum 6 02-20-2011 08:08 PM
most common gearing a tj unlimited woody69 TJ Wrangler Technical Forum 3 01-05-2009 12:25 PM
Buy a Unlimited Rubicon? Build a Unlimited X Monster? Piet JK Wrangler Technical Forum 21 05-09-2008 04:18 PM
04 Unlimited with 35's and new gearing is needed jester3798 TJ Wrangler Technical Forum 29 05-19-2007 08:24 AM
Unlimited Gearing dmullen TJ Wrangler Technical Forum 5 10-06-2005 02:56 PM
