Quantcast gear swaps - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > gear swaps
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 01-30-2008, 12:15 AM   #1
jeep_sport04
gear swaps
i have a 2004 wrangler sport 5 speed and a np231 it has a 4" lift and i want to put 33's on it but before i do i want to regear the differentials. i have a dana 30 in the front with 3.73 gears and dana 44 in the rear with 3.73. i would like to know what all i would need to swap in 4.10 in bothand can i do it all myself. i will also be putting aussie lockers in both when i do the gear swap. thanks
jeep_sport04 is offline   Reply With Quote
Old 01-30-2008, 12:42 AM   #2
Crashnburn80
4.56 is the recomended ratio for a manual and 33s. Gear install is almost always recomended to be done by a professional, not just any mechanic, a gear professional. For this reason it is not recomended for the typical home mechanic to do it themselves.
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Old 01-30-2008, 07:54 AM   #3
yeahsowhat
Why? Just inquiring.
yeahsowhat is offline   Reply With Quote
Old 01-30-2008, 07:58 AM   #4
DestructoJr
The Thin Blue Line
DestructoJr's Avatar
It requires a lot of precise measurments and there is very little leeway in doing the install. Its an expensive oops as well. Although with the FSM and general mechanical knowledge and all the required tools the setup can be done just take your time
Originally Posted by LandRover
3rd graders? Any self-respecting high school teacher could punt them like footballs. :laugh:
Originally Posted by Marneaus
10 because you're awesomely conservative and bash all the liberals. hoorah!
www.offroadoverstock.com
War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself.
--John Stewart Mill--
DestructoJr is offline   Reply With Quote
Old 01-30-2008, 07:59 AM   #5
DestructoJr
The Thin Blue Line
You will need the R&P for both diffs and a master install kit with shims and such
Old 01-30-2008, 09:47 AM   #6
Whybu1
Go STEELERS!!!!
Whybu1's Avatar
Set-up tolerance is in the 1/10000 of an inch range. Need a bearing press and a micrometer for sure. I was glad I took mine to a local guy who basically "taught" me as he did it.
Whybu1 is offline   Reply With Quote
Old 01-30-2008, 09:53 AM   #7
cvd
cvd's Avatar
Regarding lockers - the Aussie in front is a good choice (I have that). But I've read many times a full case locker (i.e. Detroit, Ox, ARB) should be used in back, instead of a lunch box locker like the Aussie.
Lunch box lockers don't ratchet as freely. You need the better ratcheting in back, which is under pressure (torque) most of the time.
cvd is offline   Reply With Quote
Old 01-30-2008, 11:10 AM   #8
Dogman
You will need a new carrier for the 44 (4.10 and numerically higher). That is unless you go with a full case locker.
Dogman is offline   Reply With Quote
Old 01-30-2008, 11:11 AM   #9
Dogman
Oh, and check this out to see what all is involved: http://www.pirate4x4.com/articles/tech/billavista/Gear_Setup
Old 01-30-2008, 12:04 PM   #10
chefdab
Are you sure about that? I asked about that when I got my 44 re-geared and they told me that I wouldn't need a new carrier. I went from a 3.73 to 4.56 and either they didn't need a new carrier or they didn't charge me for one because it wasn't listed on my sales invoice.
David
2005 LJ w/ RE 5.5 LA riding on 35"MT/Rs
"Roads, where we're going we don't need roads."
... at what point has "NEED" ever come into play when it comes to Jeep upgrades
Originally Posted by ranmannm View Post
I'm a idiot so be genital.
chefdab is offline   Reply With Quote
Old 01-30-2008, 12:12 PM   #11
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The D44 carrier break is 3.73/3.92.
The only way you can use 4.10 gears on a 3.73 carrier is if you use a "thick" gear set or a ring gear spacer.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 01-30-2008, 12:35 PM   #12
Southern Bred
I don't know if this was a typo but 1/10000 of an inch? There is nothing in the set-up of a R/P at that tolerance. Maybe the mech. was talking about the press fit of the pinion bearing?
[B][I][SIZE="3"][COLOR="DarkGreen"]98 TJ [/COLOR][/SIZE][/I][/B][COLOR="darkgreen"][SIZE="2"]RE 3.5 w/Hydro 8000 shocks, Nerf Bars, Trxus STS on MT Classic II's, Herculined tub with new Mossy Oak upholstery. Flowmaster cat back exhaust, JVC, Alpine, and Kicker stereo. Colt 485 CB, Oldie but a good one. Just getting started on this one!
[/SIZE][/COLOR]
[SIZE="3"][COLOR="Blue"][B][I]2002 Silverado LT 2500HD CC/SB 4X4[/I][/B][/COLOR][/SIZE], [SIZE="2"][COLOR="Blue"]OnStar, Black, de-badged, 295 Nittos on H2's, T-Bars Cranked, Bilsteins, Westin Nerf Bars, Brush Guard, Tail Light Guards, and Bed Caps, Tinted, PPE Hot+2 ET, Autometer Cobalt Boost & Pyro, SC III w/1056, 4" Monster Exhaust, Custom 4" Intake, Clarion Pro Audio, Alpine, Kicker Comp. Stereo. Emperor, Skullcracka, Predator, Ham/CB.[/COLOR][/SIZE]
Southern Bred is offline   Reply With Quote
Old 01-30-2008, 02:32 PM   #13
Whybu1
Go STEELERS!!!!
Whybu1's Avatar
"Thick" 4.56 gears do not require a new carrier. I did add one too many zeros on the fraction it should be 1/1000th of an inch.
Quotes taken from install directions of gears:
When changing the backlash bear in mind that the backlash setting changes about 0.007” for each 0.010” that the carrier moves. For example: Move the carrier 0.010” toward the pinion to decrease the backlash by 0.007”. Move the carrier 0.010” away from the pinion to increase the backlash by 0.007”.
While not all ring-and-pinion sets will react exactly this way, these figures serve as a good guideline.
When changing the pinion depth, make large changes until the pattern is close to ideal. Consider 0.005” to 0.015” a large change and 0.002” to 0.004” a small change. Intentionally make adjustments that move the pinion too far at first.
0.001 is 1/1000th of an inch
Glock Forum
