Quantcast Gear suggestions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Gear suggestions
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 05-17-2005, 08:33 AM   #1
jeepman14wheel
Gear suggestions
What is the recommended gears for 37" tires? The Jeep that they are going on has a I6 and manual tranny. I was leaning more towards 5.13 vice 4.88 so please help!
RE 3.5 lift, 1" BD/MT lift, 33.12.50 MTRs, Teralow, SYE, Detroit locker, Eaton E locker, Dana 44 front, Ford 8.8 rear, warn winch, full roll cage, Fuel cell.
jeepman14wheel is offline   Reply With Quote
Old 05-17-2005, 12:10 PM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I'd go with 5.13 if possible.
What front axle are you running? If it's a D30, 4.88 will be the lowest you can go.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 05-17-2005, 12:14 PM   #3
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Be wary of going to 37" tires, few parts on a TJ are up to handling that big of a tire. The front axle, ball joints, steering, etc. are all marginal for that size of tire. I'm running a Dana 44 with Superior Axle axleshafts, a Dana 30 with Warn hardened 4340 chromolly axleshafts, quality Spicer R&P gears, Currie steering kit, etc. and I won't run bigger than 35". My 4.88 gearing and lift height would easily allow me to run 37" tires, but I just ordered another set of 35" MT/R tires on Friday because I knew my TJ just isn't built enough to run 37" tires without excessive wear in the front-end. I considered 37" tires for nearly 3 seconds.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 05-17-2005, 01:41 PM   #4
jeepman14wheel
I have a dana 44 for the front axle and the rear is a ford 8.8.
Old 05-17-2005, 02:28 PM   #5
Wheelin98TJ
JEEP FREAK
I'll stick with my original recommendation then... 5.13
FYI, the 8.8 requires a modified cross shaft pin or you have to notch the ring gear to run gears this low. Just giving you a heads up in case you didn't know this. I found out when we were putting my 8.8 back together with 4.56 gears. The guys at the drivetrain shop I bought the gears from didn't even tell me!
98 TJ
Old 05-18-2005, 12:36 PM   #6
jeepman14wheel
I did not have to modify the cross shaft on my 8.8 when I went to 4.56 gears.
Old 05-18-2005, 12:49 PM   #7
Wheelin98TJ
JEEP FREAK
How did you get the cross shaft pin in? Didn't the ring gear interfere?
98 TJ
Old 05-18-2005, 05:01 PM   #8
Since you have the 8.8 the lowest you can go is 5.13. Otherwise I would go to 5.38.
????? is offline   Reply With Quote
Old 05-18-2005, 05:20 PM   #9
jeepman14wheel
The ring gear did not get in the way, it was tight but it went right in.
Old 05-18-2005, 05:43 PM   #10
dirtgrip
Highly recommend Hydro-boost if your driving on the street.It,s hard to stop on 35,s much less 37,s. http://www.vancopbs.com/hydropricing.htm
Large vacuum leak sucking all the dead presidents out of my wallet.
dirtgrip is offline   Reply With Quote
Glock Forum
