Gear recommendation for 4 cyl and 33 tires - JeepForum.com
post #1 of 11 Old 10-03-2011, 09:13 AM Thread Starter
DGRobles
Hello, I made some search but I am a little confused.
I bought a '02 TJ with 4 cylinders, 5 speed manual, it has 4.11 axles (D30 and D35), 31" tires and 3in lift. As you imagine the Jeep look not so nice with much space between the tire and the flare, so I'm planning to change those 31" for a 33" tires but I do not want to loose driveability (power and accel) considering that it's going to be my daily drive Jeep...
So, I am planning to upgrade the gear ratio to 4.56 or 4.88 but I still have doubts:
1. Whats better?.... 4.56 or 4.88?
2. Do I need to change carriers if I'm going to upgrade to any of these two options?
Thanks in advance...
Diego Robles / XE1XZQ
DGRobles is offline
post #2 of 11 Old 10-03-2011, 09:40 AM
flying_bosun
Use the gear calculator link in my sig to figure out where you want to be. Others will offer info on the hardware.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #3 of 11 Old 10-03-2011, 09:49 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
4.88's.
TheBoogieman is offline
post #4 of 11 Old 10-03-2011, 10:18 AM
robncar
robncar's Avatar
Originally Posted by TheBoogieman
4.88's.
I concur!
Sent from DROID2
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #5 of 11 Old 10-03-2011, 10:34 AM Thread Starter
DGRobles
And what about the carriers on both axles?... do I need to change them if I move to 4.88?
DGRobles is offline
post #6 of 11 Old 10-03-2011, 10:36 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
Nope, you're good.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #7 of 11 Old 10-03-2011, 10:36 AM
theducksguts
you shouldn't need to change the carrier. Carrier break is at 3.73 IIRC
Check out my
theducksguts is offline
post #8 of 11 Old 10-03-2011, 11:53 AM
MO2500
Definitely 4.88s and as others have said, you can re-use the stock carriers.
Instagram: @omsmike
MO2500 is offline
post #9 of 11 Old 10-03-2011, 01:09 PM Thread Starter
DGRobles
Great!... Thanks for the help and advice on this !!
DGRobles is offline
post #10 of 11 Old 10-03-2011, 01:26 PM
alexr40
5speed = 4.88s
1998 Jeep Wrangler 2.5L Turbo @11psi
Locked Front & Rear, 4.56s, 4:1 low range with 2LO. 35's with Beadlocks .
2005 WK Limited 4.7L - 4x4 (QT-II)
2" RC Lift, 265/70/17 BFG AT/KO, OME Rear Shocks, Saguaro Shackle Mounts, Mopar OEM Hitch
alexr40 is offline
post #11 of 11 Old 10-03-2011, 04:33 PM
mukluk
Oh, and in case you're still uncertain, go with the 4.88s
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
Gear recommendation 11 JK Apostle JK Wrangler Technical Forum 3 07-30-2011 01:08 PM
Gear ratio recommendation MagicMarc TJ Wrangler Technical Forum 7 03-29-2010 01:45 PM
Gear Recommendation Needed... syclone? YJ Wrangler Technical Forum 12 11-29-2008 10:23 PM
speedo gear recommendation jeepwcrazy TJ Wrangler Technical Forum 1 03-11-2008 08:19 PM
Speedo gear recommendation Terrain Twister TJ Wrangler Technical Forum 8 07-25-2007 09:10 AM
