Gear ratios - JeepForum.com
post #1 of 12 Old 01-10-2008, 10:44 AM Thread Starter
KMAC
Gear ratios
Does anyone have a link to a gear ratio chart for an automatic transmission. This is like all of them I have found for manual transmissions and just says the automatic transmission will be higher.
http://www.4wheelparts.com/wheelTirePackage.aspx#
then under gear ratio chart.
work in progress....
3" black diamond lift
rough country steering stabilizer
33x12.5x15 Mickey Thompson MTZs on soft 8s(coming soon)
with tire swing/bumper
shopping around for a new front bumper.
KMAC is offline
post #2 of 12 Old 01-10-2008, 10:46 AM
2jhanna
check this link.
http://www.jeepforum.com/forum/showp...80&postcount=6
jhanna
denton county, tx
2jhanna is online now
post #3 of 12 Old 01-10-2008, 05:36 PM Thread Starter
KMAC
thanks i have seen that, but I am looking for one similar to the one I have linked. Looking for one that shows a chart of automatic transmission jeep (99 3spd) with different tire sizes (31s and 33s minimum) and the axle gear ratios that make up what RPMs.
Thanks for the reply though.
KMAC is offline
post #4 of 12 Old 01-10-2008, 05:54 PM
chefdab
Check this out. (http://www.grimmjeeper.com/gears.html)
When you plug in your transmission it will tell you what the ratios are for each gear. And it will help you determine the best axle ratio for your tire size.
David
2005 LJ w/ RE 5.5 LA riding on 35"MT/Rs
"Roads, where we're going we don't need roads."
... at what point has "NEED" ever come into play when it comes to Jeep upgrades
Originally Posted by ranmannm View Post
I'm a idiot so be genital.
chefdab is offline
post #5 of 12 Old 01-10-2008, 06:05 PM
2jhanna
you can use the chart that you referenced. it is all based on a final drive of 1:1, which is what your 3rd gear auto is 1:1.
jhanna
denton county, tx
post #6 of 12 Old 01-11-2008, 07:31 AM Thread Starter
KMAC
it says with an auto my rpms will be higher do to slippage. got it, but how much higher and what will mine look like?
the other chart gets a little complicated does it have a manual?
KMAC is offline
post #7 of 12 Old 01-11-2008, 07:36 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by KMAC
it says with an auto my rpms will be higher do to slippage. got it, but how much higher and what will mine look like?...
Its about 5%.
So take the # on the chart and multiply by 1.05.
If you want perfect results, don't forget to factor in your actual tire diameter. Very few tires measure up to their sidewall height.
Wheelin98TJ is offline
post #8 of 12 Old 01-11-2008, 07:45 AM
VinoTJ
VinoTJ's Avatar
Best gear calc!
2008 Wrangler Unlimited X
VinoTJ is offline
post #9 of 12 Old 01-11-2008, 03:29 PM
2jhanna
i thought that with a lock up torque convertor that there was no slippage ???
jhanna
denton county, tx
post #10 of 12 Old 01-11-2008, 04:03 PM
Wheelin98TJ
JEEP FREAK
There is still some slippage, but it is very small.
A check engine light is triggered if slippage is greater than 3%.
I just use 5% for calculations to err on the conservative side.
post #11 of 12 Old 01-11-2008, 04:21 PM
Waldn
With a locking torque converter slippage should actually be less than a clutch.
I have found those charts to be very acurate with my set up.
97 TJ SE 2.5L Auto, 3" BDS, 255/85-16 BFG MT KM
04 KJ LTD Frankenlifted, Full Mopar Armor, front reciever hitch for winch, Rubicon Moabs and MTRs
Waldn is offline
post #12 of 12 Old 01-11-2008, 04:29 PM
JTB51B
No offense intended, but with the 2.5 do you have enough TQ to slip the convertor?
Jason
DD-- 2005 Dodge Ram 2500 Cummins TD Quad Cab 4x4 6 speed
Toys:
1998 Sport Auto trans, 3.73 gears, D30/lockright D44/Detroit, 33" Mud tires, FT LCA's JKS Adj. Trac bar FT 4" coils, RE GEN II Disco's--1 1/4 JKS BL, 1" MML XD9000i up front, HD bumpers with extraction points.-Done.
1973 cz 250 MX Not much suspension, but 36 BHP at 6k rpms!
2006 Rhino SE, 27" Mud lites and a cupholder.
JTB51B is offline
Gear Ratios vance123 TJ Wrangler Technical Forum 4 10-04-2009 08:37 AM
AX5 gear ratios RedneckYJ YJ Wrangler Technical Forum 3 09-07-2008 02:25 PM
What gear ratios should I put in? 88yj08 YJ Wrangler Technical Forum 7 08-04-2008 11:41 PM
gear ratios bmwatters TJ Wrangler Technical Forum 12 02-22-2008 10:20 AM
gear ratios mikemac4 YJ Wrangler Technical Forum 4 12-18-2005 06:24 PM
