Gear ratio question. - JeepForum.com
post #1 of 15 Old 03-18-2013, 10:06 AM Thread Starter
hrdwreman
I am trying to determine the gear ratio that is in my 00. The numbers on the diff are 07-5993-2 and 111764AB. These don't seem to be the same numbers that I have read on other threads that would tell me. I thought I had read that the first numbers would be the ratio. Thanks for any help.
hrdwreman is offline
post #2 of 15 Old 03-18-2013, 10:08 AM
jeepinhokie
based on your trany you most likely have 3.07s.
there are other ways of identifying your gear ratio though.
jack your rear end up and rotate your tire one full revolution, while rotating the tire count how many times the driveshaft spins. if it spins 3 times you have 3.07, if it spins closer to 4 you have 3.73s
HOKIES UNITED!
jeepinhokie is offline
post #3 of 15 Old 03-18-2013, 11:41 AM
2jhanna
If your rear end and cover is stock, there should be a small metal tag between the cover bolts at the 9 o'clock position. crawl under there with a rag and flashlight, the will be many numbers but you should se something like 3 07 or 3 73.
jhanna
denton county, tx
2jhanna is online now
post #4 of 15 Old 03-18-2013, 11:51 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your axle ratio is embossed into this tag as is circled in red below. The factory installed tags onto both the front & rear axles.
Getting
Jerry Bransford is offline
post #5 of 15 Old 03-18-2013, 02:12 PM Thread Starter
hrdwreman
yeah, i had seen those threads before and the numbers that are on my tags is what i put in the first thread. thus the confusion. thankls.
post #6 of 15 Old 03-18-2013, 02:16 PM
1982cj8
some of the Jeeps do not have a tag but the same numbers are embossed on the cover itself.
Always bring a compass, it is awkward to have to eat your friends.
4X4XNORTHWEST.COM
1982cj8 is offline
post #7 of 15 Old 03-18-2013, 02:20 PM
socaldaveh
You don't have to guess. Jack the rear end up, both wheels off the ground. mark a position on the tire and on the rear drive shaft. Put it in neutral and start rotating the tire. Count how many times your drive shaft rotates during one rotation of the tire. That will be your ratio.
*edit - oops, what jeepinhokie said..
You can read about jeeps all you want, but if you take a jeep that you don't love out on the trail, she'll shake you down just as sure as the the turning of the world. Love keeps her going when she ought to break down, tells you she's hurting before she dies. It's a jeep thing, you probably won't understand.
socaldaveh is offline
post #8 of 15 Old 03-18-2013, 02:37 PM
alton438
Junior Member
alton438's Avatar
the 3 on your "07-5993-2" will be right next to the bolt. It's hard to see. You have 3.07 gears.
alton438 is offline
post #9 of 15 Old 03-18-2013, 03:02 PM Thread Starter
hrdwreman
Ohhhhhh noooooooo!!
post #10 of 15 Old 03-18-2013, 04:10 PM
Jerry Bransford
Administrator
You have to rotate the tire precisely two revolutions with an open differential for it to rotate the driveshaft the correct number of times to equal the axle ratio.
Getting
post #11 of 15 Old 03-18-2013, 07:26 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Another way to determine your ratio:
3.07 = 2,000-2,100 RPM at 60 MPH
3.73 = 2,400-2,500 RPM at 60 MPH
Note: This is for 33" tires with the 3 speed auto in 3rd gear.
Last edited by Wheelin98TJ; 03-19-2013 at 11:02 AM. Reason: Added note to clarify tire size and trans gear
Wheelin98TJ is offline
post #12 of 15 Old 03-18-2013, 08:33 PM
George Dickel
George Dickel's Avatar
Me thinks if you brush the tag a bit, you'll find a 3 buried in the grime before the .07. You can't win 'em all...
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
post #13 of 15 Old 03-19-2013, 06:15 AM
jeepinhokie
that might be a difficult way to determin gear ratio. does it take tire size into consideration, or are those stock specs?
HOKIES UNITED!
post #14 of 15 Old 03-19-2013, 07:46 AM
2jhanna
tire size IS part of the equation. OP's profile states 33", I would assume Whellin98 took that into consideration.
jhanna
denton county, tx
post #15 of 15 Old 03-19-2013, 11:01 AM
Wheelin98TJ
JEEP FREAK
Yep, thanks for clarifying that.
For my calcs above, I used a 33" tire with an actual size of 32.4".
