Gear Ratio from Factory? - JeepForum.com
post #1 of 19 Old 06-27-2008, 08:16 AM Thread Starter
PSYCH0
PSYCH0's Avatar
2016 JK Wrangler
Is there any logical mapping of gear ratio to vehicle from the factory?
Example:
2006 Jeep TJ
4.0
6-Speed
No Tow Package
What gear ratio would come with this from the factory? (If it wasn't a special order)
2009 Jeep Wrangler JK, 2-Door, Soft Top, Automatic, Black Procomp Aluminum Wheels with 315x75R16 Goodyear Wrangler Duratracs, 2" Black Diamond Lift, JKS Adjustable Track Bars, Smittybilt Rock Rails
PSYCH0 is offline
post #2 of 19 Old 06-27-2008, 08:24 AM
zband
zband's Avatar
My bet 3.07's. You can always use your vin to figure to out from the Jeep site.
zband is offline
post #3 of 19 Old 06-27-2008, 08:25 AM
BYuen
BYuen's Avatar
This can be your friend:
http://www.jeepforum.com/forum/showp...04&postcount=9
EDIT: Most certainly you have 3.07s with a D35 and 6cyl. You can also check on the diff cover there should be a tag with the gear ratio on it.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #4 of 19 Old 06-27-2008, 08:29 AM
otisdog
2008 WK
If it has a D44 rear axle it will be 3.73's.
Otherwise look on this tag it could be 3 07 or 3 73
Jim
08 Grand Cherokee Overland
otisdog is offline
post #5 of 19 Old 06-27-2008, 09:25 AM Thread Starter
PSYCH0
PSYCH0's Avatar
2016 JK Wrangler
Perfect... and yes I do believe it's 3.07
Jeep isn't here now so I couldn't check the diff or I would have.. thanks!
PSYCH0 is offline
post #6 of 19 Old 06-27-2008, 09:31 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Whether a D35c has a 3.07 or 3.73 is not up to the factory, it's how the dealer orders it. I used to have a bunch of Jeep dealers as customers and whether the lot had mostly 3.07 or 3.73 equipped TJs depended on if the person ordering their Jeeps knew wtf they were doing. Most had no idea what difference it made other than 3.07 supposedly gives better mileage. It was frustrating to go onto their lots looking for new Jeeps to customize with lifts and bigger tires and find the best colors had 3.07 ratios which made them unusable for the 33" tires I usually set their Jeeps up with.
Jerry Bransford is online now
post #7 of 19 Old 06-27-2008, 09:56 AM Thread Starter
PSYCH0
PSYCH0's Avatar
2016 JK Wrangler
Didn't know that Jerry... good information! I aways 'assumed' the dealer didn't go that 'deep' into the options when they ordered them unless the customer specified they wanted something like a specific gear ratio. Like you said they don't know wtf their doing in these areas.... they should be sticking to hard top vs soft top and auto vs manual...
PSYCH0 is offline
post #8 of 19 Old 06-27-2008, 10:01 AM
zband
zband's Avatar
anyone interested here are the dealer codes (at least for 2003) for the axles and their gearing.
[BGA]=Brakes - Power Front Disc/Rear Drum
[BGK]=Brakes - 4-Wheel Anti-Lock
[BRW]=Brakes - 4-Wheel Disc
[DME]=Axle Ratio - 3.73
[DMF]=Axle Ratio - 4.11
[DMM]=Axle Ratio - 3.07
[DMU]=Axle Ratio - 4.56
[DRJ]=Axle - Rear,Dana M35/194MM
[DRK]=Axle - Rear,Dana 44/226MM
[DSA]=Axle - Trac-Lok Differential
[DSE]=Axle - Trulok Differential
I'm not sure if they change these codes much from year to year.
zband is offline
post #9 of 19 Old 06-27-2008, 10:07 AM
2005X
when i bought my X it had a 6cyl, D35 and 3:73
so dont be so sure on the 3:07gears
2005X is offline
post #10 of 19 Old 06-27-2008, 10:17 AM
outdoorlivin247
1974 CJ5
A good rule of thumb on a factory never been touched is the canyon wheel came w/ the OR package and should have a 44 rear w/ 3.73...
1974 CJ5, 2004 RUBICON, AND THE WIFES 2006 GRAND CHEROKEE SRT8...
outdoorlivin247 is offline
post #11 of 19 Old 06-27-2008, 10:22 AM
jeeperkt
My Tj came with the canyon wheels, and a D35c and 3.07s. Im not saying they all came that way but like Jerry said it really depends on what the dealer threw together.
01 Tj, RE long arm, 35s, Locked ft/rear, D44 rear, building HP D44 front
jeeperkt is offline
post #12 of 19 Old 06-27-2008, 11:39 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
OR package? Do you mean off-road?
If so, there was never an off-road package.
Wheelin98TJ is offline
post #13 of 19 Old 06-27-2008, 02:34 PM
outdoorlivin247
1974 CJ5
When most dealers order cars, trucks or Jeeps the use convenience groups...My brother in law worked @ a jeep dealer for years in F&I and ordered most of the vehicles for the dealership...He told me that the order group that had the canyon wheels had the Dana 44 and 3.73 gears in it...But as Jerry said it is up to the dealer or the person ordering the jeep to choose what it has...
post #14 of 19 Old 06-27-2008, 03:29 PM
blazer190
I've got an 06 4.0l tj x 6 speed and found my tag on the front diff cover showing 3.07. I had a bunch of random numbers on the tag at the rear. It's a 35 rear and 30 front
2006 TJ X 4.0L 6 speed 2" REBB 33x12.5x15 Trxus M/T DC-1's
blazer190 is offline
post #15 of 19 Old 06-28-2008, 06:09 AM Thread Starter
PSYCH0
PSYCH0's Avatar
2016 JK Wrangler
How are the 3.07's working with the 33" tires?
PSYCH0 is offline
Factory gear ratio for Dana35 in 87 YJ? SFM1AE2 YJ Wrangler Technical Forum 14 12-25-2013 07:07 PM
What gear ratio comes factory in a 95 yj with 4cyl and auto tranny? hartswelding YJ Wrangler Technical Forum 5 05-13-2009 07:55 AM
Factory Gear Ratio JeepN87 YJ Wrangler Technical Forum 4 03-05-2002 08:28 PM
What factory gear ratio do I have? JeepMax YJ Wrangler Technical Forum 6 03-04-2002 09:42 AM
factory gear ratio on a 93 Yj w/ 4.0 evilpsych YJ Wrangler Technical Forum 4 11-05-2001 10:22 PM
