Gear Ratio Causing Problems? - Page 2 - JeepForum.com
post #16 of 18 Old 04-19-2010, 04:02 PM
slafferty
theres a lot more than just swapping the ring and pinion, it takes a lit of time and money. The 50 dollar gears with need master install kits which are 150 a piece, then plan on 200-300 for set up on each rearend. Its pretty easy to swap the complete assemblys out of the 4 cylinder with a manual tranny (4.10) you can probaly get both rearends for under 200 bucks a piece,
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered
Originally Posted by RUBtjICON View Post
If you arent scratching it, you arent trying hard enough :tea:
MY BUILD THREAD
slafferty is offline
post #17 of 18 Old 04-19-2010, 04:03 PM
slafferty
also if the local gears are used its a little harder to set up and a lot of shops wont want to do it since they have to try to match the previous wear pattern on the gears
MY BUILD THREAD
post #18 of 18 Old 04-19-2010, 05:08 PM
BlueFlame
BlueFlame's Avatar
NO, installing gears isn't something the average mechanic will do, let alone the average Joe weekend tinkerer.
Find a reputable shop that "does gears" - find who the local 4wheelers recommend.
It will cost $1000 - 1200 total for both axles to have it done.
It is NOT a good idea to try to re-use used gears. Once they establish a pattern, they're set for life. I doubt you will find a shop that will even touch used gears.
Swapping entire axles is very simple. Quitre a bit of work involved, but it's just a bolt in deal. Get a shop manual...
BlueFlame is offline
gas mileage , gear ratio , low top speed , oil pressure
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
New LCA brackets, causing problems Howland TJ Wrangler Technical Forum 3 11-06-2009 08:08 PM
Biggest Lift Without Causing Problems dallas01 JK Wrangler Technical Forum 3 10-27-2009 09:10 AM
ac causing problems- why is my ac causing my jeep to cut off cvaria TJ Wrangler Technical Forum 6 08-07-2007 09:42 AM
Ice buildup causing problems Korruptor TJ Wrangler Technical Forum 8 12-06-2006 10:46 AM
