Gear Ratio Causing Problems? - JeepForum.com
post #1 of 18 Old 04-19-2010, 02:44 AM Thread Starter
RoyalCask
2000 Jeep Wrangler 4.0L I6, Auto.
I purchased a jeep for a steal about a month ago, and the previous owner had upgraded a lot of things on this jeep. Two of the many upgrades are 33" Tires, and a 4" lift. I have been getting terrible gas mileage, and have a hard time getting over 70MPH, god forbid I am on any incline. So, I slid under and took a gander at the gear ratio it had and it is 3.07. What gear ratio should I have with my Jeep, and these upgrades? Would the gear ratio be causing the very low MPG's, and trouble gaining speed?
Also, every so often my oil gauge will drop almost instantly from 80 to 0, and then slowly start going up, and then drop back to 0 again. After a little bit it will make it's way back to a steady 80. Any ideas?
Also, also, will I have any problems with this setup having the stock yoke and drive shaft?
My Jeep (Sorry for the bad pictures, will post better ones later.):
RoyalCask is offline
post #2 of 18 Old 04-19-2010, 08:12 AM
mainliner
Do you know of the speedometer gear has been changed? If it hasn't, then with 3.07 gears and 33s, your speedometer is going to be way off. I have the same setup and for me 70 mph on the speedo is actually 84mph. It's a near 5:6 ratio, 5 speedo/odometer miles for every 6 actual miles.
mainliner is offline
post #3 of 18 Old 04-19-2010, 08:15 AM
slafferty
with 33's and an auto 4.10's.. I'd find the stock complete rearedns out a 4 cylinder, this would save you some money. if you plan on 35's 4.56. A sye and new shaft would be better but if you dont have any viberations with your current set up you may be fine,
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered
Originally Posted by RUBtjICON View Post
If you arent scratching it, you arent trying hard enough :tea:
MY BUILD THREAD
slafferty is offline
post #4 of 18 Old 04-19-2010, 08:16 AM
slafferty
and yes an undergeared jeep will hurt power and milage, but its never going to be great
MY BUILD THREAD
post #5 of 18 Old 04-19-2010, 08:18 AM
2GPS4ME
Look at the factory info sticker near the hinges on the driver's door. My factory tire size was 205/75-15, which translates into about 27.5" diameter tires with 3.07s. That explains why I couldn't go faster than about 73mph on a flat highway, even with the 4.0 & 5-speed.
Narrow Road Jeep Garage
Owner, Operator
2GPS4ME is offline
post #6 of 18 Old 04-19-2010, 08:46 AM
Jay12
welcome to jeepforum. please fill out your profile so we can see your jeep's specs in the future. and yes if you regear your jeep will get its power and mpg back. About the driveshaft..do you have vibes? On 4" of lift you would have vibes without a change from slip yoke to the slip yoke emilinator. maybe the PO dropped the tcase?
Jay12 is offline
post #7 of 18 Old 04-19-2010, 10:17 AM
slafferty
please fill in your profile, I figured he has a d30/35 combo since he said 3.07 gears, he stated he has a 4.0 and an auto which should be the 32rh 3 speed
MY BUILD THREAD
post #8 of 18 Old 04-19-2010, 11:18 AM Thread Starter
RoyalCask
Sorry guys, I got my profile updated. I do have the 3-speed auto.
post #9 of 18 Old 04-19-2010, 11:43 AM Thread Starter
RoyalCask
I have small, and I mean hardly noticeable vibs right on take off, but that's it.
As for the ratio, is it easier to buy a kit and have it installed, or buy new axle assemblies with 4.10 ratio? I found this listing for a D35/30 set with 4.10, but to be honest I have no idea if these would work with my Jeep:
ksl.com - Classifieds for Utah, Idaho, and Wyoming
If so, $200 OBO is a nice price.
post #10 of 18 Old 04-19-2010, 11:54 AM
LJameson
You can make them work, but it's not worth the effort. Those came off a YJ and have different brackets on them. What you would do is cut them off and weld on the TJ brackets, but again it's not worth it for a d35
1990 YJ
LJameson is offline
post #11 of 18 Old 04-19-2010, 02:45 PM Thread Starter
RoyalCask
So my best bet is to find a pair that came off of a TJ? I am also thinking of holding out until I find some 44s. Would they be worth the wait, and would I be okay running my Jeep how it is until some come up?
post #12 of 18 Old 04-19-2010, 03:14 PM
slafferty
depends on your wheelng style, If you plan to stay with 33's and not to hardcore trails you'll be better off finding a 30/35 combo with 4.10's if you wanna lock the front and rear and run 35's you'll at least want to swap with d35 with d44
MY BUILD THREAD
post #13 of 18 Old 04-19-2010, 03:18 PM Thread Starter
RoyalCask
This Jeep is my dd, and it sees 95% pavement, and maybe 5% off-road action. So I am guessing stick with 30/35's. Now is it easier to just swap the ring and pinions, or the whole axle assembly. Note, I haven't ever attempted to swap ring and pinions, so this would be a first. I know a shop will probably charge an arm and a leg, is this something that a average Joe with some auto knowledge would be able to do without making things worse?
By the way, thank you everyone whose put input so far!
post #14 of 18 Old 04-19-2010, 03:22 PM Thread Starter
RoyalCask
Also, I would like to note I can get a hold of ring and pinions (4.10) for both the front and rear 30/35's for $50.00 total locally, if that plays any into having just the ring and pinion swapped. (Is that all that is needed to switch gear ratios, the ring and pinions?)
post #15 of 18 Old 04-19-2010, 04:01 PM
asknight
It's also a good idea to get a master overhaul kit for each diff @ about $100 each, as well. This includes all fresh bearings, setup shims, etc.
asknight is offline
gas mileage , gear ratio , low top speed , oil pressure
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
New LCA brackets, causing problems Howland TJ Wrangler Technical Forum 3 11-06-2009 08:08 PM
Biggest Lift Without Causing Problems dallas01 JK Wrangler Technical Forum 3 10-27-2009 09:10 AM
ac causing problems- why is my ac causing my jeep to cut off cvaria TJ Wrangler Technical Forum 6 08-07-2007 09:42 AM
Ice buildup causing problems Korruptor TJ Wrangler Technical Forum 8 12-06-2006 10:46 AM
