Gear pattern - opinions please - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Gear pattern - opinions please
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 05-29-2013, 02:49 PM   #1
beerly
Just set up this rear D35 with 4.56's. B/L is .006" with about 30-40 ft/lbs of resistance when rotating the pinion to get the pattern. Just looking for some input. Good to run? Thanks!
beerly is offline   Reply With Quote Quick reply to this message
Unread 05-29-2013, 03:31 PM   #2
pcoplin
pcoplin's Avatar
Your pics aren't as close as I'd like, but looks real good from what I can see.
98 TJ 5.9 Stretched and big axles
01 F250 Powerstroke 7.3/ZF6
pcoplin is offline   Reply With Quote Quick reply to this message
Unread 05-29-2013, 05:50 PM   #3
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Did you mean "in/lbs"?...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 05-29-2013, 06:06 PM   #4
orangetj05
Looks a little deep to me I would try removing about 3 thousands of pinion shim
2005 TJ 5.7 HEMI, Caged, Locked, Long armed, Stretched, Air shocked, Cromoed, Running 37 Irocks
orangetj05 is offline   Reply With Quote Quick reply to this message
Unread 05-29-2013, 06:49 PM   #5
freeskier93
freeskier93's Avatar
Probably not because you need to get a lot of resistance in the gears to get a clean pattern. I like to use an axle shaft to spin everything as there is a torque reduction and it takes a lot of force, easier than trying to turn the pinion and loading up the ring gear with your forearm or a board.
Also the pattern looks good, I'd run it. Could be a tad deep but it's hard to say when your not setting up he gears and see the progression.
Build Thread
My life in 2010: Chronicles of painting my Jeep
Axle Re Gear and Swap
CU Boulder Aerospace Engineering
freeskier93 is offline   Reply With Quote Quick reply to this message
Unread 05-29-2013, 07:31 PM   #6
beerly
Sorry, could have been more clear, I was talking about resistance on the ring gear and pinion, not pinion preload. I can pull a few thousandths but won't the pattern move toward the heel once under normal driving loads, being much more than I'm putting on it to take the pattern?
Unread 05-29-2013, 08:20 PM   #7
WhiteMtnJeep
The Punk Made My Day.....
WhiteMtnJeep's Avatar
I too would go a couple thousandths shallower with the pinion. It's a touch deep right now. See this from the FSM:
Your pattern should be centered, even slightly shallow is acceptable, but not more on the deep side.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Polyphase Meterman IBEW Local 387
Work with enthusiasm as though you were working for the Lord rather than for man.
http://www.treadlightly.org/
Siena Jeep Owner's Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
WhiteMtnJeep is offline   Reply With Quote Quick reply to this message
Unread 05-29-2013, 08:55 PM   #8
beerly
I'll pull .002" and see how it goes. Thanks guys
Unread 05-29-2013, 09:14 PM   #9
beerly
