Gear Pattern Help - JeepForum.com
post #1 of 3 Old 10-26-2012, 09:06 PM Thread Starter
doclouie
Gear Pattern Help
So I am at it again this weekend so forgive all the posts. Here is the drive side pattern:
Here is the coast side pattern:
So what do you think about the patterns? So do you think it is good enough to be finished? It is so subjective that it is hard to know when it is good enough. Oh yea I have .008" of backlash. Thanks for the help.
doclouie is offline
post #2 of 3 Old 10-26-2012, 09:13 PM
88hatchy
Pinion could be a tiny bit deeper, but I wouldn't worry about it.
-Will
1997 TJ - Current project: Simple-ish build
88hatchy is offline
post #3 of 3 Old 10-26-2012, 09:27 PM
orangetj05
orangetj05's Avatar
Pinion is a little to deep try pulling out around 3 thousands should get you a lot closer to a perfect pattern
2005 TJ 5.7 HEMI, Caged, Locked, Long armed, Stretched, Air shocked, Cromoed, Running 37 Irocks
orangetj05 is offline
