Gear oil? - JeepForum.com
post #1 of 8 Old 04-11-2013, 05:24 PM Thread Starter
codyking58
Gear oil?
I'm installing an aussie locker in my dana 30 tomorrow. What weight and kind of gear oil should I use? Does it matter? I live in Mesa AZ so it's hot in the summer if that make a difference. Thank you!!
codyking58 is offline
post #2 of 8 Old 04-11-2013, 05:29 PM
2jhanna
any good 75/90 or 80/90 GL5 should be fine.
this is from the faq section of the aussie site:
"Do I need special oil or lubricant?
No, use the manufacturers recommended fluid for the diff in your vehicle."
link:
http://www.aussielocker.com/frequent...tions#answer10
jhanna
denton county, tx
2jhanna is offline
post #3 of 8 Old 04-11-2013, 05:36 PM Thread Starter
codyking58
Okay thanks!! I was just wondering if a heavier oil would be okay to go with and if it would suppress the sound?
post #4 of 8 Old 04-11-2013, 05:42 PM
BYuen
BYuen's Avatar
You could use heavier oil. Not sure how much it would affect the sound. Probably not much. You won't hear the sound in 2wd.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #5 of 8 Old 04-11-2013, 06:04 PM
pmcjeep
I got the thickest gear oil Lucas makes and don't notice my Aussie at all!
01 tj 4.0,bds springs,ROKMEN arms, ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,hylined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is online now
post #6 of 8 Old 04-11-2013, 06:41 PM
1shotwonder
I'm personally running 85/140 in mine for summer time, and it's a bit cooler up here then it is in AZ
Save 1000 elk. Smoke a wolf pack
Sometimes the light at the end of the tunnel is a muzzle flash
1shotwonder is offline
post #7 of 8 Old 04-11-2013, 10:41 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
I use 80w-90 with my Aussie. You can hear it click pretty well in 2wd when turning.
May TJ of the Month 2015
TexasTJ is online now
post #8 of 8 Old 04-12-2013, 06:37 AM
Dean7276
I use 85/140. I can only hear the Aussie if the windows are down and even then its very faint.
Dean7276 is offline
