Gear hum after install - JeepForum.com
post #1 of 5 Old 04-28-2013, 07:58 PM Thread Starter
Roodki
Roodki's Avatar
I just had Alloy usa 4.88's installed in my TJ, d30 and d44 by someone who I work with who has set up many gears on his 4x4's and race cars, but it seems to have a slight howl when decelerating. Not too loud, but I can hear it. I have driven the thing about 50 miles home from his place. Is this normal? If not can this be readjusted?
Thanks
2004 Jeep Wrangler Unlimited
TSE - A Jeep Club
Roodki is offline
post #2 of 5 Old 04-28-2013, 11:51 PM
DallastheJeeper
The biggest difference between expensive gears and cheap gears is how precisely/smoothly machined they are. Alloy usa are cheap gears so they will make more noise than the well machines oe spicer gears. A slight howl is normal but I am not hearing it over the internet. If its loud definitely check the lash on both and if you have a scope peak in and check on the gears. Me and and a few of my buddies have installed many sets of usa standard gears which are also cheap and they do make noise but its not really loud.
|^^^^^^^^^^^^^^^\ ||__
|.......PBR BEER TRUCK.... ||""\_____\
|____________________/||__/----|
#5-06 Salvage Rebuild LJ
Metalcloak Bumper, Overline fenders and Corner guards.
3.5" Sus Lift
1'' Body lift and engine lift
#4-98 TJ Sahara RIP :(
#3-42 GPW Project. Currently on hold Sand blasted the body and it was held together by screen and bondo so new Tub needed
#2-88 Comanche Currently getting a frame off rebuild and a 4bt.
#1-1994 Power Wheels Wrangler
DallastheJeeper is offline
post #3 of 5 Old 04-28-2013, 11:56 PM
cavscout187
Check how deep the pinion is set not just lash if its to deep the can howl pretty laud
cavscout187 is offline
post #4 of 5 Old 04-29-2013, 05:05 AM Thread Starter
Roodki
Roodki's Avatar
Yeah, it is pretty slight. With the radio on quietly it is unnoticeable. I just want to make sure it is not going to get worse.
TSE - A Jeep Club
Roodki is offline
post #5 of 5 Old 04-29-2013, 05:27 AM
cavscout187
If its set wrong they can wear faster and get laud
