Gear Help - JeepForum.com
post #1 of 5 Old 07-01-2010, 05:58 AM Thread Starter
saharaTJ7638
Gear Help
I am re gearing my tj with the 3spd auto for 35's. I also tow a boat that weighs about 1500lbs. I guess the question I have Is what gears do I need, and what mileage increase will I get from the gear change?
My current setup is 3.73's with a 5.5" lift and 33's. Currently I get 12mpg and it really dislikes pulling the boat. The jeep has absolutly no balls when pulling and a over all sluggish feling.
I was thinking of going with 4.88's but I dont know if that will be over kill with the 3 spd. I will be running the 33's untill I get my tax return in febuary and buy a new set of tires. Also I want gears that will be DD friendly and not eat my gas as i have to drive to work everyday.
Just Empty Every Pocket
JEEP. . . It's big, It's slow, It's clumsy, it sucks on asphalt, and I love it.
SHORTBUS...YAY IM SPECIAL!!!
eugenethejeep: my mom was in here talking and being weird lol. i don't think her seeing us talk about cat tacos would be appropriate
35's and a lift kit how stuck can you get? - Justin Moore
saharaTJ7638 is offline
post #2 of 5 Old 07-07-2010, 07:45 AM Thread Starter
saharaTJ7638
thanks for the help this forum is almost useless. AND YES I ****ING SEARCHED AND DID NOT FIND WHAT I WANTED!
post #3 of 5 Old 07-07-2010, 07:57 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Easy buddy, it was a holiday weekend.
I would go with 4.56.
I used to run the 32RH 3 spd auto with 4.56 gears and I ran this combo with both 33" and 35" tires. I thought it worked pretty well.
4.88 is a little too low for the 3 speed auto until you get up to 37" tires or so.
Wheelin98TJ is offline
post #4 of 5 Old 07-07-2010, 08:55 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
definitely. i had 4.88s for about two months with 35s when i had my 32RH. it was great for driving around town, but i was turning 3k at 60. the 4.88s effortlessly turned the 35s no problem. but the 32RH doesnt have an overdrive. and that kills gas mileage. go 4.56.
Mail crawling.
MisfitSeven is offline
post #5 of 5 Old 07-07-2010, 06:13 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
4:56 gears for you...
Knuckelhead is offline
regear , regeaing , suggestions , help , towing , 33 , 3 speed
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 06:58 PM
Opinion Wanted On Gear Pattern -- New Gear Setup Jim93YJ YJ Wrangler Technical Forum 9 01-16-2011 12:14 PM
Dana 44 rubicon rear limited slip gear oil, synthetic or regular gear oil what weight rutacon05 TJ Wrangler Technical Forum 6 09-16-2009 08:53 AM
New Gear Break In..When to Do Initial Gear Lube Change?? Jim93YJ YJ Wrangler Technical Forum 8 10-14-2008 07:59 PM
Spider Gear Missing a Tooth After Re-Gear Break-in Period beertinted TJ Wrangler Technical Forum 2 06-20-2007 01:34 PM
