Gauges and radio stopped working!! - JeepForum.com
post #1 of 5 Old 02-04-2013, 01:02 PM Thread Starter
Dantheshan
Hey guys,
I have read through some other forums on this issue and I cant seem to come up with a solution that works.
I noticed a puddle in my passenger footwell after some heavy rain and then discovered that my gauges or radio wouldn't come on. I am unsure how the water got in, but I have driven it in pouring rain with the top down before with no problem. However, every once in a while the gauges and radio will start working while I am driving, but only for a couple of seconds.
I have checked the fuses, especially the IOD (#20 i think) but it is fine. Idk why they would just stop but turn on randomly sometimes. Loose wires somewhere??
Thanks!
Dantheshan is offline
post #2 of 5 Old 02-04-2013, 03:20 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Is that the only 2 things that don’t work? Is it the OEM radio?
The IOD fuse is 25 & supplies B+ power to the radio, cluster, courtesy lights & underhood light. If the courtesy lights & underhood light work it is not the IOD circuit. The gauges & radio both are supposed to only work with the key on so that also points away from the IOD fuse. I don’t see those 2 circuits having anything in common unless other things aren’t working when the radio & gauges are out.
Rubi4MyMrs is offline
post #3 of 5 Old 02-04-2013, 05:09 PM Thread Starter
Dantheshan
The courtesy lights do not work either. It is an aftermarket radio but I have had it in there for over a year now. I did some more research and I am going to pull the gauge cluster and radio and see if there are any loose wires. I read the cluster prongs on the wiring harness sometimes dont touch and you have to bend them, so I am going to try that.
I hope I can figure it out.
post #4 of 5 Old 02-04-2013, 09:38 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
True about the cluster connections but don't see how that would affect the radio unless the wiring to the radio is non-OEM connections & tied into the cluster wiring. Worth pulling the radio to see how it is wired in.
post #5 of 5 Old 02-04-2013, 10:07 PM
OR-TJ
Last time that happened to me was I blew one of the big fuses under the hood cuz I made the rookie mistake of snipping multiple wires at once... so check the fuses
Edit: nvm I missed the part where you checked the fuses already whoops
OR-TJ is offline
