Gauge failure when starting? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Gauge failure when starting?
OPTIC ARMOR WINDOWS all sale now !!!!!!!!ExtremeTerrain.com Now Carries Raxiom Off-Road Technology RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 02-14-2014, 04:21 PM   #1
Submariner
Submariner
Submariner's Avatar
05 tj inline 6.
Upon starting, the gauge failure light goes on. Oil gage does not read anything.
I turn off the engine and restart it right away. oil gage picks up and gauge failure light goes off.
160K on the engine
This only happens when the engine is cold. there is plenty of oil in engine.
I am thinking it is the oil sensor is acting up.
So what does the rest of you think about this?
This is getting to be a pain in the backside.
Submariner
With 20 years in the US Navy, and nine+ years underwater on Nuc Sub's.
And they wonder why I am the way I am!!!!!!
Submariner is offline   Reply With Quote
Unread 02-15-2014, 09:49 AM   #2
kb9lsv
how cold is it when this happens, when below 5 degrees mine takes a few seconds to get oil pressure and at times the check gauges light comes on for a couple seconds on startup. if it happens when this cold it's just that it takes the oil a few seconds to pump up due to how thick it is. throw a mechanical gauge on it and see what your pressure actually is to rule out the sending unit.
kb9lsv is offline   Reply With Quote
Unread 02-15-2014, 10:37 PM   #3
Submariner
Submariner
Submariner's Avatar
I would say 30 to 40 degrees. just after it sets all night
Submariner
Unread 02-20-2014, 07:25 PM   #4
kb9lsv
Have you puta mechanical gauge on yet ?
Unread 02-20-2014, 08:37 PM   #5
LukeADukes
Mine does the same thing. Just does it no rhyme or reason. Priming the pump by turning the key a few seconds before cranking helps but doesn't cure. It doesn't worry me
Always look both ways before crossing the stream.
LukeADukes is online now   Reply With Quote
Unread 02-21-2014, 05:38 AM   #6
TJSport97
Mine did that once while driving. Cleaned the sensor connection and hasn't done it since. Sensor is on the block next to the oil filter.
Have a nice day. Gary
TJSport97 is offline   Reply With Quote
Unread 02-21-2014, 08:55 AM   #7
Submariner
Submariner
Submariner's Avatar
I will try that this weekend.
you are right about no ryhme nor reason. only happens in the winter.
Submariner
