Gauge Cluster LED Install - Page 71 - JeepForum.com
post #1051 of 1132 Old 09-11-2012, 12:35 PM
Neil F.
My red on the HVAC shows very red. The dash is dull purple/red
Neil F. is offline
post #1052 of 1132 Old 09-18-2012, 07:42 PM
KountryKid
i orderd the LEDs you linked me to, but i dont believe they will work with mine
"Take your top off, and lets get dirty
95 2 door 5 speed cherokee, 4" lift on 32s. -sold
97 tj sahara 4.0 5 speed, full doors, hard top. 4" lift on 33s. smitty built front bumper. flush to tub tail lights
KountryKid is offline
post #1053 of 1132 Old 09-19-2012, 07:23 AM
vtx531
I got some LEDs on ebay. One of them recently started flickering. I pull the dash out and all of them are burned/melted through the plastic housing and the flickering one was melted so bad that internally a wire came undone.
vtx531 is offline
post #1054 of 1132 Old 09-21-2012, 06:29 PM
angelsfanbp
I have some extra leds from my install. $10 for 5 leds which is half of what I paid. PM me.
angelsfanbp is offline
post #1055 of 1132 Old 09-24-2012, 05:27 AM
AussieJeeper88
So this is my first post, so forgive me for being ignorant and doing it wrong, i.e. wrong section.
The question was asked earlier whether you can replace or change the colours of the lights in the stock cd player, then people just went on to say what stereo they had. So wondering, can it be done?
By the way great write up, I've only done the cluster but it looks awesome cheers.
AussieJeeper88 is offline
post #1056 of 1132 Old 09-24-2012, 09:38 AM
Neil F.
The illumination in the stereo display I believe is soldered to the boards. It depends on what color you are trying to change it to. I did see a post somewhere where the person did take apart the stereo and colored the bulb(s) with a red marker and it did illuminate red
Neil F. is offline
post #1057 of 1132 Old 09-24-2012, 09:54 AM
AussieJeeper88
Oh Ok, I have blue LED's in the dash so would be looking to do the same colour, I suppose a Blue permanent marker might work, but the lights would already have a green tinge to them so might come out some horrible purple colour. Now i guess I'll just have to find how to take apart the stereo. Cheers
post #1058 of 1132 Old 09-27-2012, 07:38 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Well I went for the cheaper version of Orange LEDs cause they were on sale for $0.99 a pair. I kinda wish I'd gone with the brighter ones, but for $6 I am happy. (sorry for bad pics)
HVAC (you can see the cut in my sticker for selecting where the air blows out from the person that broke in and ran a knife across it)
TexasTJ is offline
post #1059 of 1132 Old 09-28-2012, 05:03 PM
4banged
I installed the hd red ones in cluster on my 03 and they look good but I do have a few hot spots. Seems like the bulbs shine whiter straight ahead and more red to the sides. Overall happy but not perfect.
4banged is offline
post #1060 of 1132 Old 10-07-2012, 07:27 PM
Matt Graham
Matt Graham's Avatar
Here is my experience with swapping out the factory bulbs with the LED's in the instrument cluster, climate control, and rear wiper/defrost switches...
I ordered these from www.superbrightleds.com :
---------- PRODUCT INFORMATION ----------
Qty | Product / Options | Price/ea |
5 | NEOx-xHP: NEOx LED Bulb - High Power Instrument Panel LED| $ 2.29 |
NEO4-WHP: 4mm NEO4-xHP Cool White
5 | 74-xHP3: 74 LED Bulb - 3 SMD LED Wide Angle Wedge Base| $ 3.49 |
74-CWHP3: Cool White
SUBTOTAL: 28.90
SHIPPING: 2.99 USPS - 1st Class (Estimated)
TOTAL: 31.89
The swap was pretty easy and only took about 30 minutes or so. Here is the before picture of the instrument cluster. The bulb at the temp. guage was burned out:
When I first got everything swapped and turned on the lights it was VERY bright, except in front of the temp. guage:
I decided to try turning the bulb around in the reverse direction from how I first put it in and that fixed the problem perfectly. Here it is after that:
This is when the dimmer is all the way down, just a little less intense:
So it did only take 5 bulbs and I'm very happy with the 3 SMD LED Wide Angle Wedge Base bulbs in cool white.
There was another bulb in the middle of the cluster that I believe is in front of either the seatbelt bulb or blinker bulb. It was different than the rest because the bulb was in a black plastic holder instead of brown like the rest:
Next up was to replace the bulbs for the climate control. They were all 3 previously burned out so here is my before photo:
Here are the High Power Neo4's in cool white: (3 are for the climate control, the other two are for the rear wiper & defrost switches)
Here is the after photo:
SWITCHING BULBS IN THE WIPER / DEFROST SWITCHES
BEFORE (left) AFTER (right)
When I removed the switches to replace those bulbs I discovered at the top of one of the switches there was a bulb that was not a NEO4, I'm guessing it was NEO3 (in the white circle below). I believe that bulb is the indicator bulb that lights up behind the amber colored lense to show when the rear defrost is on.
But if you flip it over on the other side is a NEO4 bulb so I swapped the LED into that spot.
I don't really feel like switching that bulb is necessary. So the 2 NEO4's worked perfectly and did what I was hoping they would. A much cleaner and brighter light.
So if you have a 2001 TJ, or a TJ with the knob-style climate control, here is what you need and what it costs from www.superbrightleds.com :
SUBTOTAL: 28.90
TOTAL: 31.89
Definitely worth it...Now I can't wait to swap out the bulbs that light the floorboard and the interior light in the soundbar.
Instagram:
Twitter:
Youtube:
My Build Thread:
F-250 7.3 Tow Rig Build Thread:
Matt Graham is offline
post #1061 of 1132 Old 10-09-2012, 06:50 AM
Cherokid
I have a Pioneer DEH-6400BT
Another one of those, "I have a ... head unit" but I mention it because you can adjust the colour to just about anything. (I think mine has three shades of blue available all adjustable from the face plate.) It's relative inexpensive at $139.99, has all kinds of features and sounds good. I'm sure there are others as well with adjustable colours so if you don't mind spending a couple of bucks and time that may be another option. (Plus if later you want to change dash colours again it would be easy to match up the stereo.)
Good Wheelin' to ya!
Cherokid
Update: I went down and checked, 11 shades of blue available. ('cos it's one better than ten I suppose.)
Cherokid is offline
post #1062 of 1132 Old 10-15-2012, 08:19 AM
Deacon
Shining Adonis
Deacon's Avatar
Well done. Thanks!
Deacon is offline
post #1063 of 1132 Old 10-26-2012, 10:38 PM
4x4Mudmonster
I was so excited to see my package in my mail box today!! I immediately put the gauge LEDs in (cool white...and they look FANTASTIC!!) And then went to the climate control. I got it all apart and then I saw that I had the wrong LEDs ...now I gotta buy the right ones...well first find the right ones for it (1997 TJ)! lol
-Anthony-
4x4Mudmonster is offline
post #1064 of 1132 Old 10-27-2012, 04:51 AM
wwch99tj
^Same ones as your gauges 74xhp
wwch99tj is offline
post #1065 of 1132 Old 10-27-2012, 08:02 AM
jmp79
I'm wanting to change mine but positive on colorant one have pics that they could post?
jmp79 is offline
Gauge cluster trapman TJ Wrangler Technical Forum 19 05-07-2015 01:03 PM
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 05:51 PM
gauge cluster '99xjlimited YJ Wrangler Technical Forum 16 12-03-2007 07:59 AM
gauge cluster gfritzges TJ Wrangler Technical Forum 1 03-22-2007 08:17 PM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 06:39 AM
