Gauge Cluster LED Install - Page 70 - JeepForum.com
post #1036 of 1132 Old 07-11-2012, 09:57 AM
Neil F.
Note, for those with 03+, the needles are orange and with the blue leds, they are dull purple and not that easy to see 97-02 have white needles. I recently did mine white and now they glow bright blue. I pulled the needles off and the color is on the backside which I scraped off with a razor then paited white with a paint pen. I also took the orange off the center circular part and did not do it white. Too difficult to get looking sharp. There is also a tiny bit of the top of the needle that needs to be painted black. There is a tiny section of orange on the back that is difficult to get to.
Taking the needles off was no big deal. Turn the engine on an take a picture of where they are at (do it when cold otherwise the temp gauge may change on you). They pull straight off or a fork will help pry. Push them back on per the picture. The speedo, I did while driving against a GPS
Neil F. is offline
post #1037 of 1132 Old 07-11-2012, 01:26 PM
JDEEEWP
Originally Posted by 1997tjwrangler View Post
I'm really considering doing this, but I'm not sure which color. Has anyone used green LEDs yet. Would like to see those. I noticed that the colored ones make the cluster darker and harder to see in areas that are supposed to be red like at the high end of the tach. I'm worried that green LEDs would look funny in those areas. The white LEDs seem to brighten it the most I guess because there are no conflicting colors.
When selecting a color keep in mind the tint on the gauge overlays will filter all light but the color it appears. for example red will filter out all but red. this is why red areas are dim with a blue light source. There is no red light coming from the LED so you don't see much in these area.
This is why i went with White LED'. it has an electric white look to it. and you can see all the markings on the gagues.
For those looking for blue on the HVAC controls I HIGHLY RECOMMEND USING WHITE LED'S. There is blue tinting in the overlays to make the yellow stock bulbs appear slightly green. when you go with white, you get blue overlays and can still see the red on the heat adjustment! (this is also why they never match the gauges) i accedentally discovered this on my '01 when attempting a white install.
and for my next trick, i am going to go with a 3 color LED, so i can adjust color with a couple of variable resistors.
'01 TJ Sport (black), 4.0L, 5speed, Dana44, Flowmaster 50, 2"BB + OME, 32"ATs on 16" alloys.
'01 Suzuki GSX-R750(red), -1T 520 kit.
JDEEEWP is offline
post #1038 of 1132 Old 07-11-2012, 06:11 PM
smoan
Nice, i started mountain biking about a year ago and i have a cannondale trail sl2 29er
smoan is offline
post #1039 of 1132 Old 09-06-2012, 09:07 AM
skip11and1
2013 MK Patriot
How simple, thanks man!
2013 Jeep Patriot 4x4 FD1 5spd
2004 R6 lowered, stretched, full exhaust, HIDs etc
2004 TJ Columbia package long armed w/ 33's (Sold)
2005 WK, v6 QT1 (girlfriends)
skip11and1 is offline
post #1040 of 1132 Old 09-06-2012, 04:56 PM
chachi44089
Ordered red for my 04 TJ. Here are the same bulbs as v-leds at much less. Has the same inverted cone design.. $2.54 for ten with free shipping..
chachi44089 is offline
post #1041 of 1132 Old 09-07-2012, 06:39 AM
KountryKid
where did you order the LEDs from?
"Take your top off, and lets get dirty
95 2 door 5 speed cherokee, 4" lift on 32s. -sold
97 tj sahara 4.0 5 speed, full doors, hard top. 4" lift on 33s. smitty built front bumper. flush to tub tail lights
KountryKid is offline
post #1042 of 1132 Old 09-07-2012, 10:52 AM
chachi44089
Sorry, forgot to add link.. He has different colors too.
http://www.ebay.com/itm/200813577644...84.m1439.l2649
post #1043 of 1132 Old 09-10-2012, 05:44 PM
9heep7
Does the angle of the light emitted make a difference? I want a uniform light across all he gauges instead of "bright spots" where the bulbs go
9heep7 is offline
post #1044 of 1132 Old 09-10-2012, 08:33 PM
jpin321
2015 JK Wrangler
I just did blue, and as others have started here the needles are hard to see. Has anyone tried green? My jeep is electric lime green and i think matching gauges would be sweet.
"Anyone who has never made a mistake has never tried anything new." ~Albert Einstein
My Jeep History -- 1980 CJ5 > 2005 TJ X> 2013 JK Sport> 2015 JKU Rubicon > ?
jpin321 is offline
post #1045 of 1132 Old 09-11-2012, 04:09 AM
Neil F.
Neil F. is offline
post #1046 of 1132 Old 09-11-2012, 06:24 AM
jpin321
2015 JK Wrangler
^^ This doesn't really answer my question. I saw you post while reading through this thread. I don't want to remove needles and all that i can see mine well enough. I want to know what green looks like. Was wondering if someone had pics.
jpin321 is offline
post #1047 of 1132 Old 09-11-2012, 06:32 AM
Tmblack3
I put blue ones in my tj that are a very bold blue and match my sony head unit's blue lights perfectly and my AC cluster is blue but is closer to teal because of the tint on the panel. So if i put in white LEDs are you saying it will be a bright and bold blue like those?
04 TJ Sport- Kicker System, Smittybilt XRC-8 Winch, Cherry Bomb 18" Glasspack, 3" Zone Hydro Suspension Lift, 33x12.50 BFG KM2, 15x8 Procomp 7069, Aussie Locker front Dana 30, JKS 1.25" Body Lift, 4 100w Hella 500s
Tmblack3 is offline
post #1048 of 1132 Old 09-11-2012, 09:57 AM
Neil F.
Ok sorry. You said they were dull so I was trying to answer that.
Green here in this thread http://www.jeepforum.com/forum/f9/ga...37/index6.html
and here
http://www.jeepforum.com/forum/f9/ga...7/index34.html
http://www.wranglerforum.com/f5/instrument-panel-lights-blue-leds-80074-2.html
Neil F. is offline
post #1049 of 1132 Old 09-11-2012, 11:36 AM
Neil F.
I have blue leds in the HVAC and mine is very bright blue. I forget which ones I used but I believe they were whichever were the highest power. Yes if you look back through this thread, there are pictures of white bulbs in the HVAC and they shine blue, though I don't know if it will match the dash. (mine does)
Neil F. is offline
post #1050 of 1132 Old 09-11-2012, 12:23 PM
goolsbayjeep
Pics? What does it to the red tint for the heat side
goolsbayjeep is offline
Gauge cluster trapman TJ Wrangler Technical Forum 19 05-07-2015 01:03 PM
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 05:51 PM
gauge cluster '99xjlimited YJ Wrangler Technical Forum 16 12-03-2007 07:59 AM
gauge cluster gfritzges TJ Wrangler Technical Forum 1 03-22-2007 08:17 PM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 06:39 AM
