Gauge Cluster LED Install - Page 7 - JeepForum.com
post #91 of 1132 Old 04-22-2009, 01:11 PM
Keith_C
Originally Posted by Thumperyz250f View Post
Just put in my green. One section not working. Tried switching LED's and tried switching the carriers. I guess it is a bad connection somewhere inside the gauge cluster. I do not remember if the reg bulb had lit up or not.
Did you try turning the carrier 180 ??
The LEDs are polarity sensitive.
Keith_C is offline
post #92 of 1132 Old 04-22-2009, 01:27 PM
TJchuckTN
Last night I started replacing my water pump and got half way done. Today I was out there scraping off the old gasket when my new LED's(red) came in!
Thanks to the help of this write up I was done in 20 min, and it was my first time.
Originally Posted by ayeohellucks View Post
I've done the red. I'll try to get pics tonight when it gets dark. Its not really the 'red' I was looking for. Its almost pink looking.
From what I can see in the day light, they don't look pink at all. They look genuinely red. I'll put pics up tonight to let yall see what red looks like.
One draw back though...you do loose control of dim and that might be because I bought the cheapest ones, I don't know.
TJchuckTN is offline
post #93 of 1132 Old 04-22-2009, 01:46 PM
BlackBellamy
BlackBellamy's Avatar
pics of green setup pls?
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #94 of 1132 Old 04-22-2009, 01:54 PM
Keith_C
Post #80 in this thread.
Keith_C is offline
post #95 of 1132 Old 04-22-2009, 08:35 PM
TJchuckTN
Here is red
I bought the cheapest ones. I think I'll go with brighter ones in the near future.
post #96 of 1132 Old 04-22-2009, 09:02 PM
Kenbo-Slice
A couple questions....
1. does the "dim" feature still work for the dash lights?
2. has anyone tried the UV LED's?
- do you think the UV LED's would act just like a black light?.... That would be pretty cool.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #97 of 1132 Old 04-22-2009, 09:10 PM
TJchuckTN
I lost the dim feature when I put mine in. The red ones, post#96.
post #98 of 1132 Old 04-22-2009, 09:15 PM
Keith_C
Dim still works on my '03 with Greens.
Keith_C is offline
post #99 of 1132 Old 04-22-2009, 09:29 PM
Kenbo-Slice
Single LED, or triple LED's? Maybe that plays a role in the dim feature... I don't want to lose the dim, but I think I'm just gonna order some, and see what happens.
post #100 of 1132 Old 04-22-2009, 09:31 PM
Keith_C
I used singles.
Keith_C is offline
post #101 of 1132 Old 04-22-2009, 09:38 PM
ET48
Originally Posted by Keith_C View Post
I used singles.
Is the green blinding with the singles or is it just right? I was also thinking green
Also, did you try switching out the heat and A/c controls too?
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #102 of 1132 Old 04-22-2009, 09:40 PM
Keith_C
I think it's just right. I posted a pic in post #80. Looks much brighter in the pic than it really is.
Haven't tried the HVAC yet.
Keith_C is offline
post #103 of 1132 Old 04-22-2009, 09:42 PM
ET48
Yeah, saw the pic but like you said, the pic doesn't show how bright it is. Thanks man.
ET48
ET48 is offline
post #104 of 1132 Old 04-22-2009, 09:48 PM
Bennettj13
I want to see someone make it look good with the knob HVAC controls. I bought enough extra bulbs to do it, but I won't be home for months still.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #105 of 1132 Old 04-22-2009, 10:16 PM
southtxdstroyer
i dont remember where but i saw a thread where someone did the hvac controls and switches as well
automatic shifter indicator too
the hvac and switches turned out pretty darn nice
it might have been on wranglerforum or whatever that site is called
TJchuckTN, do you have the part numbers and the website you ordered yours from?
is the pic pretty accurate or is it exaggerated like some others have stated?
southtxdstroyer is offline
Gauge cluster trapman TJ Wrangler Technical Forum 19 05-07-2015 01:03 PM
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 05:51 PM
gauge cluster '99xjlimited YJ Wrangler Technical Forum 16 12-03-2007 07:59 AM
gauge cluster gfritzges TJ Wrangler Technical Forum 1 03-22-2007 08:17 PM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 06:39 AM
