Gauge Cluster LED Install - Page 55 - JeepForum.com
post #811 of 1132 Old 09-02-2011, 11:25 PM
jeepwrangler97
Originally Posted by laxin15
awesome thanks!!
Your welcome
jeepwrangler97 is offline
post #812 of 1132 Old 09-03-2011, 12:59 AM
friskeljr
Awesome thanks definately something im doing when i get back from afghan
USAF Medic SSgt
The real test comes when all strength has fled and man must produce victory on will alone...
friskeljr is offline
post #813 of 1132 Old 09-17-2011, 10:47 AM
DonRog
1997 XJ Cherokee
Purchased my LEDs 30 seconds ago. hopefully they come soon. maybe a after work project sometime this week.
Cant Wait!!
1997 Jeep Cherokee XJ
DonRog is offline
post #814 of 1132 Old 09-27-2011, 12:03 PM
DonRog
1997 XJ Cherokee
Got my lights installed today. Great write up. it was very easy and quick too. Cant wait to see them tonight. ill take pics
DonRog is offline
post #815 of 1132 Old 09-27-2011, 12:10 PM
solo97tj
hey donRog what site did u use and what bulbs did u order?
-97tj-
If in first you don't succeed...Hit Second and Gas It!!
solo97tj is offline
post #816 of 1132 Old 09-28-2011, 12:58 PM
DonRog
1997 XJ Cherokee
2 V-LEDS 3 SMT RED WEDGE BASE DASH LIGHT BULBS 37 74
those are the ones that i ordered off of the www.v-leds.com website. got them all and they all fit right in and work great. i got red ones just cuz my jeep is red but they have a ton of colors
DonRog is offline
post #817 of 1132 Old 09-28-2011, 01:15 PM
BloodThirsty
I'm seeing three different lights to order from. Which one is the correct one?
http://www.v-leds.com/24-74-NEO-LED/...orLanding/true
Blue On Black Build -
BloodThirsty is offline
post #818 of 1132 Old 09-29-2011, 08:25 AM
DonRog
1997 XJ Cherokee
http://www.v-leds.com/Interior-LED-B...98444-1-2.html
those are the ones i bought. you might be able to use the cheaper ones too. as long as they are the 37 74
DonRog is offline
post #819 of 1132 Old 09-29-2011, 09:05 AM
BloodThirsty
Thanks.
post #820 of 1132 Old 09-29-2011, 07:20 PM
solo97tj
Thanks very much going 2 order mine soon probably in white tho
-97tj-
solo97tj is offline
post #821 of 1132 Old 10-01-2011, 03:13 PM
JDEEEWP
Just did my own conversion, white LEDs for the entire dash, for about 5 bucks. (college kids pay attention)
If you get the LED's and resistors in bulk you can get them to fit the socket easily.
I bought "3mm White LED Lamps 15000mcd Free Resistors" from ebay
The resisters were about 470 Ohms, and i used two to dim them a bit in an attempt to match the brightness of the Odometer. also, two resistors fit the socket perfectly! The attached pic shows how to fit them into the instrument cluster sockets. I used sandpaper to dull the LEDs, which helped diffuse the light and eliminate most bright spots. you can also aim the led a bit in the socket if you still have a bright spot.
The HVAC controls are much easier as you can pull the old bulb out like a Christmas tree light and replace it with the LED by wrapping the wire around the socket. just don't forget the resistors, LED's can't take 12V for too long.
oh and a side note white led's are showing up BLUE in my HVAC. I may switch to AMBER LED's to get them closer to white.
Will post more pics soon.
'01 TJ Sport (black), 4.0L, 5speed, Dana44, Flowmaster 50, 2"BB + OME, 32"ATs on 16" alloys.
'01 Suzuki GSX-R750(red), -1T 520 kit.
JDEEEWP is offline
post #822 of 1132 Old 10-02-2011, 08:11 AM
DonRog
1997 XJ Cherokee
very nice and good idea
DonRog is offline
post #823 of 1132 Old 10-02-2011, 05:01 PM
DimebagDave
Might have been posted, but I went through 40 pages or more.
Anyone have a pic with the RED LED? I got a red jeep and want to put red LED's, ready to order, just want to check it out.
Thanks.
1999 Jeep Wrangler Sport 4.0L
DimebagDave is offline
post #824 of 1132 Old 10-02-2011, 05:56 PM
DimebagDave
Thanks.
Found it, Page 7. Sorry guys!
post #825 of 1132 Old 10-03-2011, 01:10 AM
DonRog
1997 XJ Cherokee
i just did mine red but if you already found them then i wont post mine. lol
DonRog is offline
Gauge cluster trapman TJ Wrangler Technical Forum 19 05-07-2015 02:03 PM
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 06:51 PM
gauge cluster '99xjlimited YJ Wrangler Technical Forum 16 12-03-2007 08:59 AM
gauge cluster gfritzges TJ Wrangler Technical Forum 1 03-22-2007 09:17 PM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 07:39 AM
