Gauge Cluster LED Install - Page 50 - JeepForum.com
post #736 of 1132 Old 05-05-2011, 10:45 PM
TheDirtyGeneral
I'm not sure thats right. I'm pretty sure he needs an 8mm and a 10mm like these http://autolumination.com/74.htm type a and b way down the page
Chris. I miss driving my Jeep. Can't wait to get into another one.
TheDirtyGeneral is offline
post #737 of 1132 Old 05-05-2011, 10:49 PM
TheDirtyGeneral
I would call them in the AM and tell them the type of bulb you need from the link I've posted and then theyll tell you which bulb that is on their site and hook you up. then you should post it here for all to know.
post #738 of 1132 Old 05-05-2011, 11:01 PM
Deacon
Shining Adonis
Deacon's Avatar
Originally Posted by Seal View Post
can't for the lift of me fin the bulbs
You said, it brother.
Deacon is offline
post #739 of 1132 Old 05-05-2011, 11:05 PM
joeksjeep
ya idk, those look like what i used for mine, and when i put in 03 wrangler thats the stuff that came up... just pull out your hvac stuff to look at the bulbs, i did haha
92 Xj 190,XXX miles needs love, and a TURBO HA!
150RwHp, 186 Lbs torque Rw, and all at 175XXX miles in my Xj
DD 98 wrangler sport 5spd 4.0 106,XXX miles
Chrysler Factory Trained Jeep technician, and A.S.E. Certified Master Tech
joeksjeep is offline
post #740 of 1132 Old 05-05-2011, 11:06 PM
TheDirtyGeneral
Mines an 06 and I used the type a and type b for the hvac. I think we would have the same you being an 03. Just call superbrightLED's if you're lucky you might be able to fish for a discount!
post #741 of 1132 Old 05-05-2011, 11:23 PM
Delta347
Just randomly came across this thread and I can say I am definitely replacing all my bulbs with ones from superbrightleds.com !!
Awesome sight and decent prices too
My iPhone will poison your Android.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #742 of 1132 Old 05-06-2011, 04:18 AM
JeeperforLife
Ok...I've done my gauge clusters and am looking to do my HVAC and switches. I have an '03 Rubicon and can't for the lift of me fin the bulbs I need that you guys are talking about (type 75 neo 4mm??). I used the cross reference guide on superbrightleds.com and didn't see these anywhere.
Maybe someone can just provide a link for my dumb***
I have an '06, and I use the 4mm, high powered, version of these...
http://www.superbrightleds.com/cgi-b...pecs%2FNEO.htm
Nate.
JeeperforLife is offline
post #743 of 1132 Old 05-06-2011, 08:05 AM
TheDirtyGeneral
Anyone figure out the bulbs for the odometer... really dont want to take out the whole dash to figure that out lol
post #744 of 1132 Old 05-06-2011, 08:12 AM
joeksjeep
ha, id tell ya the same thing as what i showed perviously they have wedge bases, but mine is prolly df from yours cuz ima 98 haha
post #745 of 1132 Old 05-06-2011, 08:14 AM
TheDirtyGeneral
But on the Odometer? Mine are sealed, I'd have to pull out the whole gauge cluster and pull back the white cover just to see what size they are so I could order. I don even know how many would be in there. I already had my gauge cluster and HVAC done for a while now.
post #746 of 1132 Old 05-06-2011, 08:40 AM
joeksjeep
ya mine were minature wedges that plugged into white bases, which in turn, turned into the back of the gauge cluster...
i didnt have to pull that white cover off, but if you do its not a big deal either
its really not a huge deal.. for me its bout literally like 8 screws.. you pull off the vin cover, pull off the plastice that goes around and under the steering wheel, then pull the 4 screws out that hold the cluster in... its on big connvector that holds it in...
the only hard part is twisting out the bases witht he bulbs. mine were extremely tight.. i used needle nose to get em out.. it was scary cuz they were so tight and i was worried about breaking them, but they fit tight for a reason...
i think there is at least 3 bulbs for the tach and speedo dials but i replased all of em and there was at least 8, 1 for each thing, like turn signal, high beam, brake light, and some others
post #747 of 1132 Old 05-06-2011, 08:42 AM
joeksjeep
look at the very first page, thats exactly how mine looked and pulled apart...
including the back of the cluster, that pic is exact, withe the turn in bulb bases and what not
post #748 of 1132 Old 05-06-2011, 10:06 AM
TheDirtyGeneral
Yeah, my 06 looks slightly different. I'll pull it out this weekend and post a picture.
post #749 of 1132 Old 05-06-2011, 10:37 AM
yellowismellow
Custom User Title
yellowismellow's Avatar
its basically all the same......simple
2006 TJ Sport
2004 WJ Special Edition
yellowismellow is offline
post #750 of 1132 Old 05-06-2011, 10:56 AM
joeksjeep
yup no biggie... believe me aftre you do a heater core on a 2008 Grand cherokee with a 5.7 or have to do a radio in a 2010 cadillac sts you will never ever complain about doing a gauge cluster in a wrangler haha
Gauge cluster trapman TJ Wrangler Technical Forum 19 05-07-2015 01:03 PM
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 05:51 PM
gauge cluster '99xjlimited YJ Wrangler Technical Forum 16 12-03-2007 07:59 AM
gauge cluster gfritzges TJ Wrangler Technical Forum 1 03-22-2007 08:17 PM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 06:39 AM
