Gauge Cluster LED Install - Page 47 - JeepForum.com
post #691 of 1132 Old 04-08-2011, 03:18 PM
Uziel
Originally Posted by mystangt View Post
Deffinetely not a 194, its way too big and it cant even fit through the holes in the cluster.
Fords use 194s and i have a ton 194 LEDs from my Mustang and i tried to make them work but they are just too big.
my 01 cherokee takes a 194 in the auto shifter and tcase shifter
Uziel is offline
post #692 of 1132 Old 04-08-2011, 03:21 PM
Stolenbmx
Originally Posted by FaT00CaJuN
I'm not quoting that huge post but umm, rotary knob hvac takes neo 4mm and a type 74 will not work as it need a base to be screwed in. I haven't taken the old haves apart yet but from what I remember they are 5mm. Someone posted it in the beginning of this thread. It boils down to for gauges- same bulb just how many. Type 74 and for hvac- 2 different models, ones a slider(I think neo 5mm) and ones a rotary (neo 4mm). For switches- neo 4mm. As for the shifter I can remember off hand the bulb but there is a cross reference on superbrightleds.com
Cajun,
OUT!
Ok good cause I got the 5mm with the screw looking base and I wanted to make sure there right, thanks alot. Someone said that you can change the OD light color but what about the blinker and shift light? Is the shift light attached to the oil gauge light? Or are they separate? And has anyone done the led for the reverse light and if so do you need anything besides the led light and if possible post the link to the led reverse light that would work with a 98 tj, thanks
Stolenbmx is offline
post #693 of 1132 Old 04-08-2011, 03:31 PM
jaythornton000
awesomeg! thanks for the write-up. ordering.
jaythornton000 is offline
post #694 of 1132 Old 04-08-2011, 07:54 PM
Michael_K
Michael_K's Avatar
I have done this some time ago myself. Just thought I'd share.
http://www.dailydriventj.com/forum/viewtopic.php?t=333
Michael K.
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline
post #695 of 1132 Old 04-11-2011, 07:23 AM
vanillathrilla
I finally ordered.. lol. I didn't get the high power LED's b/c 2003X's gauges looked great and a little softer. I'll post pictures when I get them in.
'99 TJ Sport | Rampage Frameless | 33x12.50x15 Goodyear MTR/K's | Poweraid TBS | Flowmaster 40 series | Herculined | 15% tint | LED interior lighting | AtoZ front/rear bumper | AtoZ tube rocker guards | Kenwood Excelon KDC-X993BT | Kicker 6.5's in soundbar | Alpine Type-R 4x6's in dash.
vanillathrilla is offline
post #696 of 1132 Old 04-11-2011, 07:43 AM
jersey1972fj40
great write up.
jersey1972fj40 is offline
post #697 of 1132 Old 04-11-2011, 02:21 PM
2003X
Sweet
My Build
2003X is offline
post #698 of 1132 Old 04-15-2011, 09:58 AM
Stolenbmx
Just got my LEDs and I'm going to put them in on my lunch break, thanks!!!!
post #699 of 1132 Old 04-15-2011, 01:27 PM
Stolenbmx
Just put them in, did the shift light too, the hvac was a pain but the rest was easy, positioning the bulbs so there was no dead spots took time but there not to bright and they look wonderful
post #700 of 1132 Old 04-15-2011, 02:06 PM
vanillathrilla
USPS website finally says they're out for delivery. Waiting anxiously for a reason to stop with my bathroom remodel.. I've been peeling off painted wallpaper all day, and it's an unbelievable pain in my ***.
post #701 of 1132 Old 04-15-2011, 04:28 PM
vanillathrilla
Got them installed... Didn't take long, but of course I ran into the issue of the polarity being wrong on a couple of them so I had to flip them. Very easy install!
I'm not sure if I'm going to keep the (74-BHP) blue though. There's something off about the shade of them that I'm not sure if I like, but overall it looks much better than stock. I might change those to red.
post #702 of 1132 Old 04-15-2011, 04:55 PM
Stolenbmx
Did anyone try to change the shift light? I did and it didn't work!
post #703 of 1132 Old 04-15-2011, 05:26 PM
TheDirtyGeneral
A lot of us have changed the shift light including myself.
Did you buy the right bulb? Did you try turning it around? Are you sure it's plugged in good?
Chris. I miss driving my Jeep. Can't wait to get into another one.
TheDirtyGeneral is offline
post #704 of 1132 Old 04-15-2011, 06:03 PM
Stolenbmx
Positive, I tried the same bulbs as the other gauges and when it didn't work I tried one from the h ac controls
post #705 of 1132 Old 04-15-2011, 06:55 PM
TheDirtyGeneral
in mine it's a different bulb from all of the rest. When I get home I'll tell you what kind it was
Gauge cluster trapman TJ Wrangler Technical Forum 19 05-07-2015 02:03 PM
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 06:51 PM
gauge cluster '99xjlimited YJ Wrangler Technical Forum 16 12-03-2007 08:59 AM
gauge cluster gfritzges TJ Wrangler Technical Forum 1 03-22-2007 09:17 PM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 07:39 AM
