> Models
> Jeep Wrangler Forums
> TJ Wrangler Technical Forum
Gauge Cluster LED Install
01-07-2011, 12:43 PM
#601
Very true, thanks for that correction.
01-07-2011, 12:56 PM
#602
Color temperature has been on my mind a lot lately. Both in my semi-amateur photography life, and in the house, where I have been forced by local supply and demand to go to those ugly CF bulbs. Better match your color temps there, especially in multi-bulb fixtures, and especially if you hate that sickly yellow they try to pass off as the equivalent of warm white incandescent.
01-07-2011, 01:30 PM
#603
So I heard that its illegal to have blue or red lights inside your vehicle or any combination of that. Is this true?? Dont want to draw attention with a can of Bush.
This only applies to lighting outside the vehicle. you technically can have red and blue outside the vehicle. the only thing with the lighting outside is, as far as underglow is concerned, it can't be seen more then 500 Ft from the front and rear of the vehicle. it can be on when parked or on private property. other then that have at it.. Don't quote me on it. probably wrong. i looked it up awhile ago. and that's what i thought i found. lol all well. :P the inside is far game!
-Glenn-
01-08-2011, 01:02 AM
#604
Originally Posted by JeeperforLife
Sweet, what color did you get? Make sure you post some pics when your done!!
Nate.
Im going for the updated "stock" look so I went all cool white ... I'll be sure to grab some pics.
Now that RubiJoe mentioned about the lumens rating Im gonna have to scour my order and find out if I screwed up or not!
01-08-2011, 08:00 AM
#605
A little off topic, Bowser what you shooting with? I study a little photography. Tealo, I think that sounds right, Im not really sure what FL law states. Unless youre in a rag top Cutlass bumping tunes with some color lights, the cops might then profile.
01-08-2011, 11:01 PM
#606
Originally Posted by kellyII
just replaced ever one of the dash and hvac and my push buttons for the read defrost, wiper and OD, yea I ordered the T4 and it takes the NEO wedge T3.... UGH!!!!
so for your 05 thr hvac lights are t3 or t4?
can you send me the link to it please!!!!! thanks alot!
01-09-2011, 12:53 AM
#607
LOVE IT!!!! i have to do this to mine
01-09-2011, 09:04 AM
#608
Well I'm going to be doing this mod ASAP. But first I would like to know, will these LED's be the right ones?
http://www.v-leds.com/Interior-LED/G...98444-1-2.html
"Just because you got the monkey off your back doesn't mean the circus has left town."
01-09-2011, 12:56 PM
#609
Here is the link to the NEO twist locks for the climate control panel
You need the NEO-4XHP .. 3 of them
These also light up your switches (1 per switch) ... If you also want to light up the switch indicators you need NEO-3XHP (1 per switch)
01-09-2011, 12:57 PM
#610
Originally Posted by Jeeper2610
Those are them
01-14-2011, 10:27 AM
#611
the link didnt show up  lol
01-14-2011, 11:47 AM
#613
thanks alot!
just ordered red for my hvac controls!
01-14-2011, 08:36 PM
#614
Well... I suck! LOL ..
Sorry bout that .. Thanks for the save Nate!
Hey .. I installed all cool white lights at the shop the other night ... Looks real good ... If anyone is wondering, white lights in the climate control panel illuminate everything bright blue while maintaining the red arc on the temperature setting ... Looks good and clean ...
White lights in the switches make the switches illuminate white. Indicator remains orange. Not sure about the shifter yet because the console isn't in. Pics soon!
01-14-2011, 09:51 PM
#615
just did mine in blue.
on a slightly related note, my CEL bulb burned out from being on constantly. lol
[/Kevin]
Jeep TJ pictures|Jeep XJ pictures|nightcrew
_____________________________________________
2000 TJ-amber fire, 2.5L, AX5 transmission, NP231 transfer case, 1" t-case drop, D30 front, D35 rear, 4.10 gears, 4" Rubicon Express lift, 33x12.50 Goodyear Wrangler Dratrac tires, 15x8 American Racing steel D-window rims, 3 chime train horn, Viar 450C compressor with 6 gal tank, CJ tailgate, CJ/YJ hard top with XJ roof rack, soft top, Dynomax Super Turbo cat-back, HD ZJ steering, bedliner, SRC rear bumper w/tire carrier
1990 XJ "Dead End"-amber fire, 4.0L, AW4 transmission, D30 front, D35 rear, 3.55 gears, 235/75/15 Goodyear Wrangler Duratrac tires, 15x7 TJ rims, 2001 front clip
1993 XJ forest green, 4.0l, 2wd, AW4 trans, D35 rear, 3.55 gears
