Gauge Cluster LED Install - Page 21 - JeepForum.com
post #301 of 1132 Old 12-25-2009, 06:28 AM
incagoldjeep
does anyone have a picture of how the hvac neo 4 bulbs are suppossed to look like? im buying them from v-leds and not sure if the bulb i have is the right one. i know most people got it from superbrightleds but im already a customer at v-leds and they should have the bulb. is this it?
2 SMT HIGH POWER AMBER WEDGE BASE LED LIGHT BULB 37 74
or this?
2 V-LEDS 3 SMT AMBER WEDGE BASE DASH LIGHT BULBS 37 74
incagoldjeep is offline
post #302 of 1132 Old 12-25-2009, 07:33 AM
ilovegeeksnj
if your ordering from v--leds trust me get the cheap ones they are bright enough 1.50 for pair cluster use code toyotanation for discount and buy extra
ilovegeeksnj is offline
post #303 of 1132 Old 12-25-2009, 08:43 AM
incagoldjeep
did u buy your hvac leds from there? if u did can i get a link plz. cuz idk which one is right
post #304 of 1132 Old 12-25-2009, 09:08 AM
ilovegeeksnj
I got them all from v-leds all the same bulbs, I ordered 10 for extras and or broken ones- heres the part # V-LEDS Part ID: 74_B I was wrong they were 2.50 a pair my total was 16.50
post #305 of 1132 Old 12-25-2009, 11:08 AM
incagoldjeep
oh yea ur jeep is a 97 and mine is an 03 and the hvac controls are different and they have different lights
post #306 of 1132 Old 12-25-2009, 12:11 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
Originally Posted by jeep_punk View Post
pics of the blue?
how bout lookin on the 1st page........
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #307 of 1132 Old 12-25-2009, 01:42 PM
BigJake87
inca if your ordering from vled, for the hvac its the 74 t4's.
2 SMT HIGH POWER AMBER NEO WEDGE BASE LED LIGHT BULBS T4
or if you go to superbrightled they're called neo4's
BigJake87 is offline
post #308 of 1132 Old 12-25-2009, 01:52 PM
incagoldjeep
thanks man. that helps alot
post #309 of 1132 Old 12-25-2009, 06:00 PM
haulincats
I really want to do this upgrade but am confused on which
bulbs I need.
I have a 98 TJ, I want to do the dash, gauge cluster,
which ever its called, high low beam, odometer,
the HVAC and the auto shifter, anything else I can
in blue.
Can someone give me a complete parts list for the
bulbs I need. I don't care which place I order from.
Thanks,
Vance
haulincats is offline
post #310 of 1132 Old 12-25-2009, 06:33 PM
BigJake87
2 SMT HIGH POWER BLUE WEDGE BASE LED LIGHT BULBS 37 74 x 3 pairs for gauge cluster (5 bulbs for gauge 1 bulbs for high beam optional)
2 SMT HIGH POWER BLUE NEO WEDGE BASE LED LIGHT BULBS T4 x 2 pairs for hvac (3 bulbs for knob style or 2 bulbs i think for slider) these can also be used for stock switches.. fog lights, rear wiper, etc.. one bulb each located at the bottom of the switch.
2 V-LEDS BLUE HIGH POWER BULBS 194 168 158 2821 2821 x 1 pair (one bulb for shifter)
post #311 of 1132 Old 12-25-2009, 07:42 PM
incagoldjeep
isnt it the same bulb used for the hvac as the gauge cluster with the sliders. im guessing since u hvae a 98 most likely u have the sliders. which means u get another pair of the 37 74
post #312 of 1132 Old 12-25-2009, 09:00 PM
haulincats
Yes I have the slider controls. So I need another pair of the 37 74
And I don't need any of the T 4?
But I do have 2 toggle switches I need to change
Thanks,
Vance
post #313 of 1132 Old 12-25-2009, 09:32 PM
incagoldjeep
ok the toggle switches take the t4 but since u have a 98 ur gauge cluster and hvac controls use the same lights so just add 2 more lights for the 37 74. u might want extras just incase one of them dont work. also if one side doesnt work switch the led 180 degrees and try the other side. its basically trial and error. so dont install the lights and put everything back together. i installed the lights and plugged it back in and used a towel to make the gauge cluster dark so i could see which ones i needed to fix. if u got any questions just let me know.
post #314 of 1132 Old 01-06-2010, 08:24 AM
incagoldjeep
did anyone actully remove the green film in the newer knob style hvac controls? just wondering if it makes a difference at all?
post #315 of 1132 Old 01-06-2010, 10:03 AM
gotmudd1
Originally Posted by xantasm View Post
I did the LED dash and HVAC conversion, also did the dome light LED conversion, LED turn signals and LED tailight/reverse conversion. I went with this company though because their bulb identification makes more sense than the VLED site which just goes by measurements:
Super Bright LEDs - Miniature Wedge Base Bulbs
5 #74xHP in blue for the dash
3 Neo4 twist loc bulbs in blue for the HVAC
2 4410-x9 Festoon Bulb in blue for the dome lights
2 1157 (BAY15D) - Dual Contact and Dual Intensity in red for the brake lights
2 1156 (BA15S) - Single Contact and Single Intensity in white for the reverse lights
2 25-LED 3157 wedge bulbs in amber for the front turn signals
2 921-x12 Wedge Base bulbs in amber for the side markers
3 Neo5 (Dbl check size when ordering, not sure which I used?) twist loc bulbs in blue for the lower bulbs in the toggle switches
2 Neo3 twist loc bulbs in blue for the upper bulbs in the toggle switches
And bought the ORO LED Relay switch, which is hands down better than anything else I tried, and after getting pissed from the Stu-Olsen Relay conversion not accomplishing the task and a NAPA LED relay not working either. I have a 2005 LJ and stock relay doesnt like to be modified apparently. Hope that list helps for anyone looking to do LED conversion. Here is two pics of the dash and HVAC in blue, not much I could do about the RB1 LED's so they are still the oem bluish green and the locker toggle bulb isnt accessable which is actually a good thing IMO so you dont get it confused with the others.
Do you have a picture of the turn signals and tail lights with the LED bulbs?
97 Wrangler: 4.0L, 5 speed, BB, 31's KM2's, CAI, Cat-Back Exhaust
gotmudd1 is offline
Gauge cluster trapman TJ Wrangler Technical Forum 19 05-07-2015 01:03 PM
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 05:51 PM
gauge cluster '99xjlimited YJ Wrangler Technical Forum 16 12-03-2007 07:59 AM
gauge cluster gfritzges TJ Wrangler Technical Forum 1 03-22-2007 08:17 PM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 06:39 AM
