Gauge Cluster LED Install - Page 17 - JeepForum.com
post #241 of 1132 Old 11-05-2009, 04:29 PM
mhaskin
Just ordered all the stuff to do my TJ from V-LEDs. I used a coupon code COMMANDER15 and saved 15%. Hope that helps someone.
I also ordered a huge light for the overhead. I will let you guys know if it works.
HID WHITE 36 LED DOME/RV/CAMPER BULB 194 168 906 921
mhaskin is offline
post #242 of 1132 Old 11-05-2009, 06:47 PM
ilovegeeksnj
i was using toyotanation code. v-leds guy is awesome sent refund for non working bulbs. i just ordered amber 3157 & 164 for my crystal clear corners and sides he upgraded bulbs for me looks great.
ilovegeeksnj is offline
post #243 of 1132 Old 11-08-2009, 09:33 AM
Mushrabbit
Such a great thread. Perfect instructions. Was simple... other than putting four out of five bulbs in the wrong way.
And the bulbs inserting into the bases like Christmas tree lights... made me remember why I hate replacing bulbs on Christmas light strings!
Mushrabbit is offline
post #244 of 1132 Old 11-09-2009, 11:28 AM
mhaskin
Just installed the 36 LED overhead light. It took 2 minutes and looks really cool. Can't wait to see it at night. The only negative is that it does not bolt in place, I have it wedged in place now. Hopefully it won't bump around, or else I will have to get creative to mount it.
mhaskin is offline
post #245 of 1132 Old 11-15-2009, 02:02 PM
mJUSTINm
awesome thread, im definitely going to do this soon once i get a few other things done first.
-Justin
mJUSTINm is offline
post #246 of 1132 Old 11-15-2009, 04:05 PM
Stoked99
I've had 2 LED's go out on me - one in the upper left of the dash and one behind the A/C controls. I haven't had the time to go take apart anything to check them out, but the one behind the A/C controls sometimes works and sometimes doesn't. Any ideas?
Vice President - Low Output 4 Cylinder Jeep Club
'98 2.5L - RC 2.5 - 33's - Beach Cruiser
"Aerodynamics are for people who can't build engines" - Enzo Ferrari
Stoked99 is offline
post #247 of 1132 Old 11-15-2009, 04:07 PM
PurpleTJ
take them out and check them. we arent going to make them magically start working again.
Purple Jeep Club member #8
PurpleTJ is offline
post #248 of 1132 Old 11-15-2009, 04:15 PM
Stoked99
Are you sure? It would make everything a lot easier
I meant any ideas for when I check them if it's not obvious what is causing them to not light?
Stoked99 is offline
post #249 of 1132 Old 11-15-2009, 04:57 PM
ilovegeeksnj
I Had To Fiddle With Them A Little Bit To Get Some To Work
post #250 of 1132 Old 11-15-2009, 05:33 PM
0blcktj6
You now officially need to do a writeup on the HVAC, toggle switches, and the Dome light...or post a link to the writeup you used..I already did the dash LED's but it looks weird in red with everything else being that greenish stock color. Thanks.
3" Currie progressives, OME Shocks, 1" BL, 1" MML, 35x12.50" KM2's, 4.88's, Detroit in rear, Vanco BBK, Currie CA's
My Build Thread:
0blcktj6 is offline
post #251 of 1132 Old 11-16-2009, 01:02 AM
mJUSTINm
so when you change the color of the gauges the needles change too? is there a way to do blue gauges with a red needle, or red gauges with a white/blue needle?
-Justin
mJUSTINm is offline
post #252 of 1132 Old 11-16-2009, 02:41 AM
therdlesstravld
Is there a way to tint the superwhite leds to make the light a dark gray? My interiors all black with dark gray seats and I think having the gauges dark gray would set it off nice. Any ideas from specific paints to films to put over the lights?
therdlesstravld is offline
post #253 of 1132 Old 11-16-2009, 03:31 AM
gone-broke
Originally Posted by ET48 View Post
I wonder if there is an easy way to remove the green film....?????????
You can remove the green film...
Ranger Power Sports Forum - View Single Post - My finished COMPLETELY BLUE LED dash
gone-broke is offline
post #254 of 1132 Old 11-16-2009, 04:51 AM
ET48
Awesome! Thanks.
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #255 of 1132 Old 11-19-2009, 03:53 PM
simadownow6988
Originally Posted by gone-broke View Post
link dont work....
simadownow6988 is offline
Gauge cluster trapman TJ Wrangler Technical Forum 19 05-07-2015 01:03 PM
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 05:51 PM
gauge cluster '99xjlimited YJ Wrangler Technical Forum 16 12-03-2007 07:59 AM
gauge cluster gfritzges TJ Wrangler Technical Forum 1 03-22-2007 08:17 PM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 06:39 AM
