Gauge Cluster LED Install - Page 11 - JeepForum.com
post #151 of 1132 Old 05-01-2009, 02:56 AM
corndogduff
So i finally got some pics of my setup... ****ty cell pics but you get the jest of it i think
it wouldnt let me show you the cluster cause its too big but its just white LEDS with a red needle if you can picture that
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
corndogduff is offline
post #152 of 1132 Old 05-01-2009, 08:24 AM
BJORN98TJ
Which LED's did you use for the switchs for the rear wiper and the defrost? I've done my gauges and the HVAC, but my switches are still stock colored, and it's ugly. And also, how did you get into the switches, I pulled them out and they looked sealed? Maybe I don't know
BJORN98TJ is offline
post #153 of 1132 Old 05-01-2009, 11:16 AM
Oregun
In the HVAC, does the "red heat" still come through as a Bright red, or is it purple now? Does it show up better in person? Looks good
Oregun is offline
post #154 of 1132 Old 05-01-2009, 11:24 AM
hyperboarder
1992 XJ Cherokee
i did my cluster and the shifter today, it looks f'ing killer!
o and i put the extra #194 array that came with the one for the shifter in the soundbar... blue illumination for the back looks SICK! gonna install the HVAC bulbs tomorrow and order more for the footwell lights, gonna look way cool
and no, im not a mallcrawler, girls just like this stuff for some reason
What bulb are the footwell lights, 194 as well?
hyperboarder is offline
post #155 of 1132 Old 05-01-2009, 01:16 PM
corndogduff
Its the same bulb as the HVAC, just pull the switch out of the bezel and it untwists from the bottom
the red shows up great, albeit slightly dimmer than before but its still red and still visible
Yes, the footwells are#194 just like the soundbar
okay, here's a complete list of what i bought and where:
from V-Leds:
3 packs of #74 tri LED (2 per pack)
3x #194 tri LED for interior illumination
from autolumination:
6 t4 blue LED bulbs (one in the foglight switch, i just havent hooked the switch back up since i dont use it)
all of the LED's i ordered are advertised as the "brightest"(most expensive) on their pages, i did this to make sure they matched my stereo
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
post #156 of 1132 Old 05-01-2009, 01:57 PM
Oregun
Leprachaun , since you just had it apart, how many bulbs are needed behind the HVAC, If you don't have the switches.
Oregun is offline
post #157 of 1132 Old 05-01-2009, 02:01 PM
BJORN98TJ
mine took two! one in the top left corner, one in the bottom right corner
post #158 of 1132 Old 05-01-2009, 02:04 PM
corndogduff
it takes 3 if you have knobs, two if you have sliders
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
post #159 of 1132 Old 05-01-2009, 02:05 PM
Oregun
Damn, that's it?
Leprachaun, why did you order 6?
Oregun is offline
post #160 of 1132 Old 05-01-2009, 02:18 PM
all_clear
Damn, that's it?
Because he did 3 in the HVAC switch, 1 in each of the defrost and wiper. And the foglight switch.
2004 Jeep Wrangler, Auto Trans, LEDs throughout, 3" Lift, 35" MTZ's
Check out my official RE-build thread. Her name is Ilene
all_clear is offline
post #161 of 1132 Old 05-01-2009, 02:55 PM
Oregun
Thanks dude
Oregun is offline
post #162 of 1132 Old 05-01-2009, 03:43 PM
Bennettj13
Duff, can you post a link to the t4 bulbs you got from autolumination? That is probably one of the worst websites I've ever looked at.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #163 of 1132 Old 05-01-2009, 03:53 PM
Oregun
^I agree...
Oregun is offline
post #164 of 1132 Old 05-02-2009, 12:47 AM
corndogduff
you just gotta kinda scroll honestly... theres no way to just link to it
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
post #165 of 1132 Old 05-02-2009, 02:49 AM
Bennettj13
Is it called something other than t4 then? I didn't see t4 anywhere I looked, and there is no search function on that website that I found.
Gauge cluster trapman TJ Wrangler Technical Forum 19 05-07-2015 01:03 PM
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 05:51 PM
gauge cluster '99xjlimited YJ Wrangler Technical Forum 16 12-03-2007 07:59 AM
gauge cluster gfritzges TJ Wrangler Technical Forum 1 03-22-2007 08:17 PM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 06:39 AM
