Gauge Cluster LED Install - Page 10 - JeepForum.com
post #136 of 1132 Old 04-26-2009, 03:22 PM
all_clear
Originally Posted by AngryLeprachaun View Post
just so im clear, the auto shifter is the same bulb as the cluster, correct?
No mine isn't its a bigger bulb then the dash cluster lights. I tried to get my 6th led to go in and work and it doesnt make enough contact.
2004 Jeep Wrangler, Auto Trans, LEDs throughout, 3" Lift, 35" MTZ's
Check out my official RE-build thread. Her name is Ilene
all_clear is offline
post #137 of 1132 Old 04-26-2009, 03:22 PM
Kenbo-Slice
I put in some Ultra Violet bulbs yesterday. I'll post pics later. I gotta post some pictures of my chopped up front fenders too. lots of "little" mods this weekend.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #138 of 1132 Old 04-26-2009, 03:36 PM
corndogduff
ok so i did some searchin through the FSM and the auto trans bulb is a 194
i just ordered all my LED's on priority shipping, pics when they are done
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
corndogduff is offline
post #139 of 1132 Old 04-26-2009, 06:33 PM
jtehren
I got a set of the cheapest ones in red. They're not bright enough and kind of pinkish. I also put 2 in for the ac slider control panel and you can barely see it. Idk if there was a film or something to take off or just insert the bulbs. Anyone know if the more expensive bulbs in red work better? Thanks. Will get pics soon too
jtehren is offline
post #140 of 1132 Old 04-26-2009, 07:06 PM
Stoked99
Ok here are some pics. Ended up cutting out another piece of white paper and laminating it with two pieces of packing tape. Worked well and slid right in. Here are some pics of everything lit up.
and for the shifter, my camera really didn't pick it up very well, but like I said it's more blue-green. Once my new LED's come in I'll take some more pics.
Overall I love them. They really do show up a lot better in person...maybe I just need a different camera setting
Stoked99 is offline
post #141 of 1132 Old 04-27-2009, 07:09 AM
DARKBLUETJ
Definitely go with the tri-leds. Due to their design, they have a wider range of beam, which means a more even and uniform glow. Also, the dimming feature should work better with the tris than the singles, because the single leds dont draw enough power in the first place to make the dimming resistor effective. Tri-Leds draw 3 times as much power than singles, so the dimming resistor should work better.
Just so I'm clear:
for an 04 tj
I need:
5 #74 bulbs (Gauge Cluster)
2 #t-4 bulbs (HVAC)
1 #194 bulb (shifter)
did I get anything wrong?
Yesterday is gone, Tomorrow is yet to be, and Today is for wheelin.
/l ,[____],
l---L -0lllllll0-
()_) ()_)--O-)_)
DARKBLUETJ is offline
post #142 of 1132 Old 04-27-2009, 07:14 AM
all_clear
Just so I'm clear:
for an 04 tj
I need:
2 #t-4 bulbs (HVAC)
I have an 04 and the HVAC has 3 bulbs, thats if your not going to do the O/D switch. But everything else looks right.
I got the blue 3 bulb and my dimmer works its not like incandescent bulbs but it shouldn't be expected to be...
post #143 of 1132 Old 04-27-2009, 07:25 PM
rubicon1000
anyone know where to get white needles i have a 03 with the red needles and they do not show up very well with blue leds i did a search but didnt turn up much
'12 unlimited sport S, 3.73, trac loc, towing package, rubicon unlimited springs and shocks
SOLD 03 Rubicon , nv 3550 ,4'' RC lift ,1'' RC MM lift, 1.25'' body lift, HD rear bumper, hummer snorkel cap with buick airbox and custom piping, 265/75 r 16 tread wright retread mud tires on stock rubicon wheels, smitty built 8k winch, cobra cb radio, rrc front bumper, pre-runner rear bumper, HID headlights in Hella housings
rubicon1000 is offline
post #144 of 1132 Old 04-27-2009, 08:26 PM
GoldenP51
GoldenP51's Avatar
I saw on ebay some gauge needle paint...but I wouldn't do that because adding the weight to the needles will probably screw up their readings. Mine don't show up all that well either with the blue LEDs...I've been thinking about switching out to white because of it.
GoldenP51 is offline
post #145 of 1132 Old 04-28-2009, 06:23 AM
Jeep25
I did the white lights last night.
Not sure if it's a common problem, but really had to work on them for all 5 to work. Needed to pull out the wires on the lights to make better contact with the plugs.
Otherwise it looks great. The whites are very white and make the factory look yellowish and dull.
Jeep25 is offline
post #146 of 1132 Old 04-29-2009, 08:47 PM
LordBronz
1994 XJ Cherokee
Can anyone tell me how many and what type tri-led red LEDs I need to a 94 XJ?
littleblackXj - You are the man!
xjfever - So are you!
LordBronz is offline
post #147 of 1132 Old 04-30-2009, 01:13 AM
corndogduff
i did my cluster and the shifter today, it looks f'ing killer!
o and i put the extra #194 array that came with the one for the shifter in the soundbar... blue illumination for the back looks SICK! gonna install the HVAC bulbs tomorrow and order more for the footwell lights, gonna look way cool
and no, im not a mallcrawler, girls just like this stuff for some reason
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
post #148 of 1132 Old 04-30-2009, 02:11 AM
GoldenP51
GoldenP51's Avatar
PICS!
10 charac
post #149 of 1132 Old 04-30-2009, 08:34 PM
Kenbo-Slice
here are some ULTRA VIOLET LED's. Sorry for the blurry pic.
WOW.... I didn't realize how ****ty the picture actually was. Sorry about that.
post #150 of 1132 Old 04-30-2009, 09:04 PM
rubicon1000
i see a ghost
Gauge cluster trapman TJ Wrangler Technical Forum 19 05-07-2015 01:03 PM
interior lights not working after gauge cluster LED install mJUSTINm TJ Wrangler Technical Forum 4 02-10-2010 05:51 PM
gauge cluster '99xjlimited YJ Wrangler Technical Forum 16 12-03-2007 07:59 AM
gauge cluster gfritzges TJ Wrangler Technical Forum 1 03-22-2007 08:17 PM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 06:39 AM
