Gauge Cluster Changes - JeepForum.com
post #1 of 6 Old 11-08-2007, 09:42 PM Thread Starter
89MustangGX
I noticed in my Brother's 97 Sahara that his gauge cluster has all numbers on the gauges (Specifically the Oil Pressure, but all of the gauges), but in the 04 and 06 Sports I have looked at they have just a H and L on that gauge. The Water Temp and other gauges still have proper indicators.
Was this a change in clusters at a certain year or in trim levels? What year did it happen? Is it possible to swap them?
I searched and found nothing.
Just curious -- nice to have numbers I suppose...
Adam
89MustangGX is offline
post #2 of 6 Old 11-08-2007, 11:02 PM
Rocky529
Rocky529's Avatar
It's not worth it for numbers, your gauges still act the same as his.
The change happened in 2001 I believe, or atleast when the Cherokee was discontinued.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 6 Old 11-09-2007, 12:05 PM
BlueFlame
BlueFlame's Avatar
yes, the numbers on the speedo and tach are different too.
BlueFlame is offline
post #4 of 6 Old 11-09-2007, 06:08 PM Thread Starter
89MustangGX
Thanks guys.
I guess the next question is, when this changed did the accuracy also change? Would they now be more of dummy gauges than actual gauges or was it just the face that changed?
Adam
post #5 of 6 Old 11-10-2007, 10:38 PM
BlueFlame
BlueFlame's Avatar
If you're thinking of changing to the new cluster, I dont' think you can. There's differences in the engine and the rest of the vehicle - the cluster has a lot electronics in it - it's not just a gauge panel.
Crappy pic but here's what the back side looks like:
post #6 of 6 Old 11-10-2007, 11:46 PM
Rocky529
Rocky529's Avatar
Originally Posted by 89MustangGX
Thanks guys.
Adam
Nothing more, nothing less.
Rocky529 is offline
Gauge cluster trapman TJ Wrangler Technical Forum 19 05-07-2015 01:03 PM
How to the gauge cluster? jagarcia82 YJ Wrangler Technical Forum 3 03-14-2010 09:37 PM
gauge cluster?!?!?!?!?!?! tcaz10 YJ Wrangler Technical Forum 10 01-31-2007 06:39 AM
Gauge Cluster Help daynknight YJ Wrangler Technical Forum 20 10-13-2005 12:14 PM
Used Gauge Cluster qteasy TJ Wrangler Technical Forum 1 02-07-2004 02:07 PM
