Gauge cluster - JeepForum.com
post #1 of 4 Old 09-25-2012, 11:06 AM Thread Starter
boatertim221
Gauge cluster
New problem, at lunch all gauges quit working. Odometer works, lights, radio, cig lighter all work just non of the gauges. I checked the fuse and even replaced, still nothing. Any ideas????? Wondering if it isn't time to get rid of the TJ.
boatertim221 is offline
post #2 of 4 Old 09-25-2012, 12:37 PM
karik
is the air bag light on?
common failure. 1/2 hour max to fix.
it's the connectors on the cluster loose. remove cluster and tweak each pin really carefully a degree or two.
karik is offline
post #3 of 4 Old 09-25-2012, 12:40 PM Thread Starter
boatertim221
Airbag light has been on for a while.
post #4 of 4 Old 09-25-2012, 12:44 PM
karik
yupp, i had exactly the same problem. loose connection on one of the two connectors.
needle nose plyers, bend each pin a tiny bit and be really careful on re-connection.
there's a few threads here on the same problem.
no gauges, air bag light on.
karik is offline
will a gauge cluster from a 95 yj fit a 89 yj???? fixxit413 YJ Wrangler Technical Forum 15 09-05-2010 06:19 PM
Anyone ever taken apart a gauge cluster?? malo8899 TJ Wrangler Technical Forum 3 05-26-2010 04:35 PM
How to the gauge cluster? jagarcia82 YJ Wrangler Technical Forum 3 03-14-2010 09:37 PM
Need a new gauge cluster for 88 yj DP88yj YJ Wrangler Technical Forum 3 12-09-2009 02:16 PM
YJ Gauge cluster microtek YJ Wrangler Technical Forum 3 07-26-2002 01:09 PM
