gasket maker safe to use on IAC housing? - JeepForum.com
post #1 of 8 Old 06-27-2013, 08:26 AM Thread Starter
CrawlThis2004
Hey everyone I took my IAC housing off the throttle body of my 2004 jeep wrangler 4.0l to clean it. Well I used blue sensor safe rtv on It to seal it back up will this be OK to use for awhile? Thanks
CrawlThis2004 is offline
post #2 of 8 Old 06-27-2013, 08:48 AM
JBTJ
Well since you already have done it!!! Why not get the correct gasket or make one?
JBTJ is offline
post #3 of 8 Old 06-27-2013, 08:50 AM
NotURMailman
NotURMailman's Avatar
I would say that as long as you didn't get carried away to where chunks of it can get stuck in the valve you should be OK.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #4 of 8 Old 06-27-2013, 09:01 AM Thread Starter
CrawlThis2004
Well if they made a gasket for the IAC housing I would I've looked everywhere so has other ppl on forums no luck. So yeah either make on or use rtv. The rtv holds really good makes a tight fit. I don't trust gasket paper or me making one.
post #5 of 8 Old 06-27-2013, 09:09 AM
jeepmutiny
1983 CJ7
There should be just an o ring on the IAC ........Jon
jeepmutiny is offline
post #6 of 8 Old 06-27-2013, 09:15 AM Thread Starter
CrawlThis2004
Yes there is for the IAC when it goes into the housing.
post #7 of 8 Old 06-27-2013, 09:22 AM
JBTJ
I use cereal boxes. They make perfect gasket material.
JBTJ is offline
post #8 of 8 Old 06-27-2013, 09:39 AM
jeepmutiny
1983 CJ7
I do the same cardboard trick for housing shims LOL...Jon
