Gas Tank Won't fill all the way - JeepForum.com
post #1 of 22 Old 12-03-2007, 10:00 AM Thread Starter
jonesy02
Hey guys, i've come to notice that when i fill my gas tank, the clicker thingy cuts off way before its full. Like 2.75 - 3 Gallons before spilling out.
What could be wrong with it to cause this (this was not from 1 fill or just 1 station, i've been testing it for about a month at lots of different stations, all about the same)
I've checked my build sheet and i'm supposed to have the 19 gallon tank as well.
jonesy02 is offline
post #2 of 22 Old 12-03-2007, 10:03 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Don't stick the gas nozzle in so far.I put it just past the openeing flap
TheBoogieman is offline
post #3 of 22 Old 12-03-2007, 10:20 AM
beryl
are you sure your tank is completely empty?
i can get my needle all the way down (1/4" past the E mark) and still go about 20 miles (and still never ran out)
06x-6speed...hard/soft top, BPE's, 2" coils, 1" PA BL, 32 bfg mt's, 15x8 MT alloys, big daddy rocker guards, flowmaster, RE gen II discos, rear bumper and tire carrier, 10" MTX sub with 800watt kenwood amp, mossy oak mats, sony stereo
beryl is offline
post #4 of 22 Old 12-03-2007, 10:29 AM
LeatherCharm
This happened to me the other day. I onyl got it up to 3/4 full when it stopped. Then the next time i started my jeep, it said it was full
LeatherCharm is offline
post #5 of 22 Old 12-03-2007, 10:30 AM Thread Starter
jonesy02
I'll try that
For the not being empty all the way, why would that matter when the clicker clicks off? It should click off once it gets to a certain amount of fuel right? I'm not worried about the total amount of fuel going in, that just when it stops auto fueling i can still add almost 3 gallons before gas starts coming out.
jonesy02 is offline
post #6 of 22 Old 12-03-2007, 10:39 AM
Manateu
Wreck?
I was rear-ended recently and the new tank doesn't hold the same as the OEM. I think the insurance company installed a smaller tank. Did you have a wreck? This was a lesson to always do your own repairs, so you get the right replacement parts.
2004 Unlimited LJ
Indianapolis, IN
Manateu is offline
post #7 of 22 Old 12-03-2007, 10:43 AM
UnsanePyro
The same thing happened to me last winter, my tank wouldn't fill up all the way, it would click a couple of gallons short of where it did before. I never found out why. It hasn't happened this year though. Hopefully someone knows why
UnsanePyro is offline
post #8 of 22 Old 12-03-2007, 10:43 AM Thread Starter
jonesy02
Carfax was clean (know that doens't always matter) and it doesn't appear to have had any body work on it.
but it does actually hold 19 gallons, just have to fill last 2.5 - 3 gallons w/o the auto fill thingy on.....
jonesy02 is offline
post #9 of 22 Old 12-03-2007, 10:57 AM
FLATFENDER54
FLATFENDER54's Avatar
Mine wont fill when i have the nozzle inserted all the way. I always have to put the nozzle in all the way then pull it out an inch or 2 to get it to fill up. (my brothers and fathers TJ's are the same way)
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #10 of 22 Old 12-03-2007, 11:00 AM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
Mine will auto shut off immediately if it is inserted all the way. Usually in just far enough so it stays. A few pumps don't like the flow rate at full volume either.
As for teh 19 gallon question; Jeep fuel gages are notoriously pesimistic. At "empty" there is still a good amount of fuel left in the tank.
Whybu1 is offline
post #11 of 22 Old 12-03-2007, 11:07 AM
djt283
djt283's Avatar
The nozzles are designed to turn off with very little backflow so people don't end up pumping gas all over the ground. If the nozzle is in too far and the gas is coming out directly into a turn in the filler hose, the splashing will turn off the nozzle. Also, as your tank fills, a little pressure builds up and can cause the same thing. Just a safety.
djt283 is offline
post #12 of 22 Old 12-04-2007, 05:03 PM Thread Starter
jonesy02
tried today without sticking gas nozzle in all the way, same thing, gas light came on around 200 miles, put in like 12 - 13 gallons before it clicked off. Sounds like I dont have a 19 gallon tank? But i have put 17 - 18 gallons into it before. How does the tank know when to click it off?
jonesy02 is offline
post #13 of 22 Old 12-05-2007, 07:09 AM
Whybu1
Whybu1's Avatar
How much gas you can put in is not a good indicator of the size tank you have. Most likely you have a good bit of fuel left in the tank when you are on empty. Jeeps are known to do that. Almost never really empty when it says they are, esp if you go by the light. I have driven well after the light and to the point the needle was almost below the dot for empty and got all of 15 gallons in. If you really want to test it out, get a 5 gallon gas can, fill it and put it in the back. Then drive till you stop. Add the gas and then go fill up. See how many total gallons it takes. Will give you a good idea how how far you can really go after the light also.
Whybu1 is offline
post #14 of 22 Old 12-05-2007, 07:21 AM
FLATFENDER54
Run it emtpy and youll know for sure. I would bet you have a 19 gallon tank. My light seems to turn on when I have like 5 gallons left int the tank
post #15 of 22 Old 12-05-2007, 01:15 PM
kevin_dubay00
When it auto shuts off do you have a full tank?
I noticed at some stations the damn thing would shut off every two seconds when I was just begining to pump (obviously not even close to full). Did some research and found somone said turning the nozzle a bit so it is not perfectly straight down (say like 4oclock position) and pumping like that would stop it and it worked for me.
Can't use autofill but I never do anyhow.
kevin_dubay00 is offline
Gas Tank won't fill jonesy02 TJ Wrangler Technical Forum 10 12-10-2009 09:23 AM
Gas tank won't fill?! bfaas TJ Wrangler Technical Forum 11 11-01-2009 01:01 PM
Gas tank will not fill all the way abadjay TJ Wrangler Technical Forum 30 09-30-2009 02:43 PM
Couldn't fill my tank this AM?!? YlwColumbia TJ Wrangler Technical Forum 15 08-07-2004 11:49 PM
eye dropper to fill gas tank?? jeepthang23 YJ Wrangler Technical Forum 7 08-02-2002 07:45 AM
