Gas tank skid that requires no tank removal - JeepForum.com
post #1 of 28 Old 12-31-2005, 06:36 PM Thread Starter
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Anybody know of a gas tank skid that could simply bolt on, without having to remove/drop gas tank?
Thunderstrike is offline
post #2 of 28 Old 12-31-2005, 06:55 PM
roofdown
I believe the Skid Row gas tank skid mounts over the stock plate.
http://www.jeepreviews.com/jeep-part...ow-skidplates/
roofdown is offline
post #3 of 28 Old 12-31-2005, 06:57 PM
UCTJ
UCTJ's Avatar
I have the Skid Row and its a very stout skid...installs very easy...good product.
UCTJ is offline
post #4 of 28 Old 12-31-2005, 07:32 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Thanks! Skid Row for me!
post #5 of 28 Old 12-31-2005, 09:45 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Just reviewed it again, and also read the Kilby. I like Kilby giving you 1" additional clearance, but gotta drop the tank.
post #6 of 28 Old 12-31-2005, 09:59 PM
FmrVette
FmrVette's Avatar
2008 XK Commander
How much clearance do ya lose with the skid installed?
Jim
"Basically, I'm for anything that gets you through the night - be it prayer, tranquilizers or a bottle of Jack Daniels. - Frank Sinatra
"When the last Blackhawk helicopter goes to the boneyard, it will be on a sling under a Huey." - Every Huey pilot that lived through it.
'95 YJ, '00 XJ, '06 TJ, (Current:) '08 XK
FmrVette is offline
post #7 of 28 Old 12-31-2005, 10:48 PM
UCTJ
UCTJ's Avatar
To be perfectly honest I dont know the exact amount but just from using a high tech eyeball....Id say not enough for me to really worry about...pretty much the thickness of the skid which is 3/16 of an inch then maybe a total of 3/8 of an inch...just guessing though...for me its not enough to even care about.
UCTJ is offline
post #8 of 28 Old 12-31-2005, 11:58 PM
EaglesSJ
EaglesSJ's Avatar
I would go with kilby for the simple fact that you gain an inch of clearance and with a skid row you lose clearance. Its not that bad pulling your tank I done it last week to put on my tire carrier I made.
EaglesSJ is offline
post #9 of 28 Old 01-01-2006, 01:18 AM
D`Nyed
1997 XJ Cherokee
The only bad thing about the kilby is the need for a 1" body lift.. no biggie if you have one already... or plan on one regardless.. but if you didn't answer yes to one of those then the kilby won't work (actuallY I read that the Unlimited doesn't require a body lift and i'm now too lazy to see if that's what you're driving in the first place)
I'd love something like the kilby that's a complete replacement skid so I don't lose any clearance.. but it doesn't require something else I may not have or want such as the body lift.
I'm very tempted to go for the kilby myself and see what I can do about horseshoeing it in there without the body lift... muahahah
Now: 97 XJ - Stock - Mods if I ever have money
4th: 97 TJ - Sold (wife's)
3rd: 04 TJ - Sold (much regret)
2nd: 01 XJ - Sold
1st: 89 XJ - Sold
D`Nyed is offline
post #10 of 28 Old 01-01-2006, 08:42 AM Thread Starter
Thunderstrike
2009 JK Wrangler
OK. Looks like I'll be dropping the tank.
post #11 of 28 Old 01-01-2006, 10:15 AM
SpoolinU
SpoolinU's Avatar
According to their advertisement info on Swissmountain.com they don't require a body lift for 97-02 but I guess 03's + do. Score for us older models!
"Kilby Enterprises - Gas Tank Skid - TJ 97-03 Wrangler / TJ
The Wrangler/TJ skid has been moved to the passenger side by 3/4" to allow for more shock clearance on the driver side and it raises the tank up another 1" for increased clearance over stock setups and even more vs other skids that go over the stock shield. The front has a new design allowing 3/4" more differential clearance over the previous design. More material has been removed from the front of the skid to give the track bar more room to cycle. This skid will fit 1997-2002 TJ's without a body lift with slight modification to the tank straps. 2003 Wranglers will require a 1" body lift due to the new changes. "
SpoolinU is offline
post #12 of 28 Old 01-01-2006, 10:40 AM
daFoo
I just ordered the Skid Row from their web site becuase they have a different model for the Unlimited (which I haven't seen in the on-line stores).
I'm sure I'll be happy with the plate. Right now I have a 2 inch spacer lift and the 3/16 inch drop doesn't bother me. Messing with the gas tank does bother me. I put a small hole in my 94 tank from a tweak in the stock skid plate, and that cost me $350 for a rubber patch to be put on it (non-dealer). The Dealer said it would cost about $1000 for a new tank and labor, and you can't but an after market replacement tank! Skid Row for me!
1950 Willies Jeep Sold!
94 SE YJ Sold!
2005 Rubicon LJ Sold!
2007 Yellow Rubi 4 door. 2.5 TeraFlex Lift, 4 Rancho Grab handles, Yellow Silblade Wipers.
daFoo is offline
post #13 of 28 Old 01-01-2006, 11:01 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I've been real happy with my Tomken gas tank skidplate for the past 9 years. It's held up to some pretty major impacts on rocks, some so hard it was kinda scary. Tomken's was the first really good skidplate that came out for the then-new TJ.
Jerry Bransford is offline
post #14 of 28 Old 01-01-2006, 04:06 PM
Wooders
1975 CJ6
Dropping the tank isn't really a hard job - and it's a chance to clean some of the crap youve probably accumulated there
I currently have the Kilby & have nothing but high paise for it & it's been abused pretty hard.
Cheers
Wooders is offline
post #15 of 28 Old 01-01-2006, 04:09 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
I've run the Skid Row for a couple years, and have beat the crap out of it...with no problems...
as mentioned, a quick and easy install right over the factory tank and skid without having to remove it...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
09 JK gas tank skid plate removal?? jbco JK Wrangler Technical Forum 10 01-11-2012 09:47 PM
99 gas tank skid plate removal dummerdrummer TJ Wrangler Technical Forum 5 10-02-2008 04:19 PM
Gas tank skid removal - spinning bolt thejafe TJ Wrangler Technical Forum 4 10-01-2008 01:59 PM
gas tank skid bolts spin-cant drop tank dodgetk81 TJ Wrangler Technical Forum 0 04-08-2008 08:18 PM
gas tank skid plate removal LeftoverSalmon TJ Wrangler Technical Forum 7 07-10-2004 08:25 PM
