Gas Tank Skid Repair / Gas tank skid bolts - JeepForum.com
post #1 of 6 Old 07-06-2009, 09:34 PM Thread Starter
noise_maker
So I dropped my malformed stock gas tank skid (my 2000 has the supper flimsy one). After giving up finding a cheep junkyard replacement I just decided to beat the dents out till the jeep piggy bank has more money (Just had to do axel seals, and a starter)
I got it down easy as pie. Beat it with my BFH and it came out pretty good. Not perfectly square but pretty good.
I went to put it back up and had a terible time with the bolts. Only one of them didn't just spin when I tried to put the nut back on.
It took my buddy and I about 2 hours to get it all up and secured.
Word to the wise - if you do this - buy tank straps ahead of time. I busted one of mine (even after soaking in PB two days ahead of time). I ended up using one of those universal ones on one side - its OK but not as good as the stock ones.
Does anyone have a good way to re-secure those bolts coming out of tub? I am planning on replacing the skid eventually and and just looking for ideas. Spending forever with a tiny screwdriver and a set of needle nose trying to the the nuts to tighen down again does not seem like a good time.
noise_maker is offline
post #2 of 6 Old 07-06-2009, 09:45 PM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Best solution I can offer is to tack a weld onto the top of the nuts.
Or remove the bolts and see if nutserts can take their place.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #3 of 6 Old 07-07-2009, 04:32 PM
Rubicon_Rob04
Pushnut bolt retainers will hold the square head of the carriage bolt down in channel.
Rubicon_Rob04 is offline
post #4 of 6 Old 08-01-2009, 12:29 AM Thread Starter
noise_maker
Any Idea where I can get these? I checked at a couple local hardware stores and they did not have anything like that.
post #5 of 6 Old 08-01-2009, 12:49 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Send Gerald an email and he will most likely toss some in an envelope for you. We have thousands of them that we use when we supply new ones with our skids.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #6 of 6 Old 08-01-2009, 12:53 AM
roadkill
check the HELP section of the auto parts store
roadkill is offline
Fitment issue with new gas tank and gas tank skid drum03 YJ Wrangler Technical Forum 3 10-02-2009 08:34 PM
What are the long bolts on the bumper side of the gas tank skid plate for? 01amberfirewv TJ Wrangler Technical Forum 2 06-30-2008 03:09 PM
gas tank skid bolts spin-cant drop tank dodgetk81 TJ Wrangler Technical Forum 0 04-08-2008 09:18 PM
Those 2 long bolts by the tank skid... SimonTuffGuy YJ Wrangler Technical Forum 12 08-27-2006 10:26 AM
Gas tank skid that requires no tank removal Thunderstrike TJ Wrangler Technical Forum 27 01-09-2006 12:41 AM
