Gas Tank Skid Plate - JeepForum.com
post #1 of 6 Old 08-31-2005, 12:04 PM Thread Starter
soontobeinsand
Gas Tank Skid Plate
I was wondering which companies make gas tank armor that you don't have to drop the tank to install, or if you get better protection with a plate that requires a drop, remove OEM cover, and then reinstall the new plate around tank.
soontobeinsand is offline
post #2 of 6 Old 08-31-2005, 01:13 PM
U.S.MarineLJ
U.S.MarineLJ's Avatar
Skid Row doesn't require you to drop the tank, fits right over the stock skid. That is what I'm currently running.
If you want a gastank skid with more clearence go with a Kilby but 03 or newer Jeeps require a body lift. Also, I'm pretty sure you have to drop the gastank in order to install it, I could be wrong though. Perhaps someone with more experience with the Kilby could chime in here.
Great site to read about and review Jeep related products.
Awesome site with writeups.
Another awesome site for writeups.
U.S.MarineLJ is offline
post #3 of 6 Old 08-31-2005, 01:24 PM
Grimmjpr
I was able to install my Warn gas tank skid on my 04 Rubi without dropping the tank. It was a pain since i was doing the install alone, but well worth it for the extra clearance, gave me about an inch over stock. I do run a JKS BL, and from what i understand Warn has re-designed their skid and does not offer any more clearance over stock....I'm not totally sure on that though. I have an older one i got prior to the recall/redesign.
I used ratchet straps around the seam of the tank to hold it up while i swapped the skids. I had the tank hella empty when i did this. Hope this helps.
2012 JK Rubi - Cosmos Blue/5 speed auto
04 TJ Electric Lime Green Rubicon - Bunch of extras. Cha-Ching - Gone
97 TJ Lapis Blue Sport - Gone
Grimmjpr is offline
post #4 of 6 Old 08-31-2005, 01:27 PM
matty427
yes - you have to drop the gas tank for the Kilby
matty427 is offline
post #5 of 6 Old 08-31-2005, 03:33 PM
Freakshow
Freakshow's Avatar
Yes, you have to drop it, but it's well worth it. You get an extra inch clearance, and it's not that hard to drop the tank.
-Rob
For sale!
'00 Cherokee - RE 4.5" with 33x12.5 Mickey Thompson Baja MTZ
Freakshow is offline
post #6 of 6 Old 08-31-2005, 04:11 PM
Ross
the kilby is a fairly easy install if you have an extra set of hands.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
Gas tank skid plate Que89YJ YJ Wrangler Technical Forum 12 03-06-2009 08:40 AM
Gas tank skid plate Lee3333 YJ Wrangler Technical Forum 7 06-13-2008 06:32 PM
gas tank skid plate NPerry05X TJ Wrangler Technical Forum 3 10-30-2005 04:49 PM
TJ gas tank in a YJ skid plate?? David K. YJ Wrangler Technical Forum 0 05-11-2005 07:42 AM
Gas tank skid plate FastX YJ Wrangler Technical Forum 2 09-13-2002 06:52 AM
