Gas overflow fix hose problem with GM hose - JeepForum.com
 1Likes
post #1 of 17 Old 09-21-2012, 03:28 PM Thread Starter
olaverty
So I have had the GM fill hose installed for several months now with no problems at all with the overlfow. However, over the last month or so, I noticed that the gas pump would click off more and more, until within the last week I've had to pump the gas extremely slow so as to keep the handle from clicking off. Today I took off the GM hose, which still looked fine on the outside, no visible kink as I had installed a hose clamp on the bend. But looking inside, it seems the inner part of the hose had separated at the bend and bubbled inward, restricting the flow of gas and thus causing the pump to click off. The fix was easy, I cut out the flapper and stuffed it in the old OEM hose that I had kept, put a hose clamp around where the flapper sits, and just filled it up full speed and no overflow. Hope this helps anyone with this problem. Pics of the GM hose below.
olaverty is offline
post #2 of 17 Old 09-21-2012, 05:20 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Thanks for the info. I've been considering moving the flapper to my old hose but since it's been working I haven't done it.
Rubi4MyMrs is offline
post #3 of 17 Old 10-11-2012, 06:38 PM
SurferJ
any more pics or description of how you did this? i just ordered the hose for my YJ and if i cant get the hose to fit, i'll try this method
SurferJ is offline
post #4 of 17 Old 10-11-2012, 07:06 PM Thread Starter
olaverty
Sorry no more pics. Basically just slit the gm hose with a razor like you see in the pic above, the flapper assembly will just fall out. Then I pushed it into the bottom of the TJ hose, and pounded it on with a deep well socket the same diameter as the inside of the hose as far as I could. Then tightened around the flapper with a hose clamp for good measure. Real easy to do.
olaverty is offline
post #5 of 17 Old 10-11-2012, 08:05 PM
Madmunki
Which way does the flapper go? I'll move mine to the tj hose this weekend.
Madmunki is offline
post #6 of 17 Old 10-11-2012, 08:11 PM
goldeagle06
How did you guys fix it so it shuts off when full. I have an 06 tj and it doesn't click off until its already coming out
goldeagle06 is offline
post #7 of 17 Old 10-11-2012, 08:16 PM Thread Starter
olaverty
You want it opening toward the tank, so that when the back flow hits it, it shuts and stops the back flow. The hinge should be at the top.
olaverty is offline
post #8 of 17 Old 10-11-2012, 10:35 PM
Slobert
Thats genius. I like this better than trying to get the GM hose to fit. Too bad we can't just buy the flapper valve and skip messing with a hose we don't need.
Slobert is offline
post #9 of 17 Old 10-12-2012, 11:16 AM
SurferJ
Can't wait for my hose to come into the dealer. If not today I have to wait till Monday
SurferJ is offline
post #10 of 17 Old 10-13-2012, 06:44 PM
2405TJ
Thanks for the post Iíll remember this if I start having problems with the complete GM hose installation.
UncleMaddog likes this.
2405TJ is offline
post #11 of 17 Old 10-15-2012, 09:54 PM
SurferJ
got the hose today...... hoping to do this tomorrow
SurferJ is offline
post #12 of 17 Old 03-14-2016, 11:37 PM
Lory
Add another one to this thread, but I am a 2003. Mine does not splash back, it just clicks constantly, for the whole fill. You cannot get past 1/2 trigger pull.
There is a "valve" in the plastic inlet throat to the tank, it looks like it is to keep fuel in the tank in a roll over. Not sure what else it might do. There is a little spring that provides a slight pressure against the flow. Does anyone have any experience with this "valve" thingy?
Lory is offline
post #13 of 17 Old 03-15-2016, 06:17 AM
JEK3
JEK3's Avatar
Lots of folks have had this (rollover valve) stick. Sometimes it sticks open, causing fuel splashback. Sometimes it sticks shut, causing problems getting fuel to go in.
JEK3 is online now
post #14 of 17 Old 03-15-2016, 07:30 AM
stripperguy
search for inlet check valve...this is a common problem and the valve can and will stick anywhere from full open (spit back issue) to nearly closed (slow fill issue).
I had my GM flapper hose delaminate on the inside too. Eventually, I bought a new OEM filler hose and installed the GM flapper in it.
Unfortunately, thta inlet check valve is an integral part of the tank and no one has yet devised a simple solution to replacing/refurbishing it.
1977 CJ5 is a CJ build ever really done?
2002 TJ gone
2005 TJ also gone
2005 LJ insurance wreck
stripperguy is offline
post #15 of 17 Old 04-01-2016, 10:02 PM
Lory
Solved!!!!
It was indeed the roll over valve. Too many words to describe the happy happy. It is a small white plastic piece that the filler hose clamps to in the top of the tank.
Lory is offline
Coolant overflow tank hose leaking?? Meng TJ Wrangler Technical Forum 7 08-16-2012 05:45 AM
Fuel Filler Hose and Adjacent Hose BrianGr TJ Wrangler Technical Forum 10 01-13-2012 03:43 PM
DTC 1486: Pinched or blocked hose in the evaporative hose system. andrewnovell TJ Wrangler Technical Forum 0 10-11-2009 04:59 AM
Gas hose problem Garbe YJ Wrangler Technical Forum 3 05-31-2007 08:53 PM
Hose thats under the heater core hose DirtyDog YJ Wrangler Technical Forum 4 07-23-2006 01:41 PM
