Gas getting into my oil - JeepForum.com
post #1 of 6 Old 01-19-2013, 01:56 PM Thread Starter
Felber
Somehow gas keeps getting in my oil. I recently just changed my oil a few hundred miles ago and it already smells strong of gas. Also the oil level is now high. I removed the fuel rail looking for a leaking injector but could not find one. I don't know what to do, maybe buy all new injectors? My jeep is a 99 wrangler with the 4.0. Any help would be greatly appreciated! Thanks
Felber is offline
post #2 of 6 Old 01-19-2013, 03:51 PM
TimV
Sounds like a bad fuel pressure regulator.
It's not an addiction. It's a way of life.
TimV is offline
post #3 of 6 Old 01-19-2013, 04:11 PM
Terdar
How do your plugs look? See if one is fouled.
Terdar is offline
post #4 of 6 Old 01-19-2013, 05:39 PM
durango-bob
2006 WK
The most common way for fuel to get into the oil is past the rings. You could have excessive wear or some other sort of piston damage. I recommend a compression test as the first step to see if one cylinder is worse than the others.
durango-bob is offline
post #5 of 6 Old 01-19-2013, 06:51 PM Thread Starter
Felber
I don't see a pressure regulator. Also i just replace the plugs, wires, distributor, and rotor hopping it would fix the problem but it didnt. Also i hate to think that it has bad rings since it only has 100k miles.
Felber is offline
post #6 of 6 Old 01-19-2013, 06:52 PM
JBD
intake manifold gasket
JBD is offline
gas , jeep wrangler , need help , oil , smell
