Gas filler tube/neck? fix - JeepForum.com
post #1 of 13 Old 07-11-2010, 10:08 PM Thread Starter
WeeVon
Newbie ???? Takes for ever to put gas in my TJ. Goes slow, keeps shutting off. Several of us have tried, is this problem inherent to this model, to California's restrictcions? Is there away to fix it? That is a 1/2 hr I could spend on the trail. Thanks for your help.
WeeVon is offline
post #2 of 13 Old 07-11-2010, 10:42 PM
Benderff
Benderff's Avatar
Make sure the neck is not bent or kinked. If not it must be the roll over valve.
Benderff is offline
post #3 of 13 Old 07-12-2010, 04:51 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
do you have a body lift?
Mail crawling.
MisfitSeven is offline
post #4 of 13 Old 07-12-2010, 06:45 AM Thread Starter
WeeVon
Thank you
She is stock. No lift yet! Will check for kinks, is the roll over valve easy to replace? Thanks for your help.
WeeVon is offline
post #5 of 13 Old 07-12-2010, 11:03 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Are you talking about the ball-check valve in the vent tube?...
Knuckelhead is offline
post #6 of 13 Old 07-12-2010, 11:11 AM
Benderff
Benderff's Avatar
Yeah I believe that's it.
Benderff is offline
post #7 of 13 Old 07-12-2010, 11:58 AM
Knuckelhead
AFSOC Retired
I don't think thats a roll over valve, it just stops you from overfilling the tank.
The gas cap has a pressure valve in it that prevents spillage...
post #8 of 13 Old 07-12-2010, 12:17 PM
danielbuck
1946 CJ2
If I try to fill mine with the pump at full squeeze, it'll just click. What I do is squeeze it lightly (less than 1/2) for the first gallon or so, and then usually it'll let me go full squeeze from then on. Might be my imagination, but the closer to empty my tank is, the more "1/2 squeeze" I need to do, sometimes the first 2 gallons.
My mustang has the same quirk, guess I've just gotten used to it. For mine, it only takes another minute or so to fill up, so I've not bothered to try and see if there's a fix. yours is taking 1/2 an hour? wow, haha!
danielbuck is offline
post #9 of 13 Old 07-12-2010, 01:29 PM
NorCalCon
I have the same problem. Some gas pumps are worse than others. Some pumps work well if I only Squeeze the nozle half way, others I have to rotate the nozle to make it work without clicking off. I think it has something to do with the Vapor Recovery System that the gas nozle uses. I've just left several gas stations with like 1/4 of a tank because I didn't want to mess with the clicking issue.
NorCalCon is offline
post #10 of 13 Old 07-12-2010, 01:41 PM
Apex
Recon death squad
Apex's Avatar
Instead of jamming the nozzle all the way, pull it about half way out.
Works for me.
Apex is offline
post #11 of 13 Old 07-17-2010, 08:05 AM Thread Starter
WeeVon
I guess it is just slow then. Nothing appears to be wrong, if I fill with gas can, goes fast. No it is not really 1/2 hr, but it sure feels like it. lol Thanks everyone for your help. I am sure I will be talking to you all again.
WeeVon is offline
post #12 of 13 Old 07-17-2010, 09:58 AM
BYuen
BYuen's Avatar
Works for me.
Yup this trick works for me too.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #13 of 13 Old 07-17-2010, 09:50 PM Thread Starter
WeeVon
Will try it. Thank you.
WeeVon is offline
tj , wrangler , gas , fill , fuel , slow
Gas leaking from filler neck JIBTEXHNKA YJ Wrangler Technical Forum 3 04-13-2010 04:30 PM
Fuel filler neck issue after bl Cajun78 TJ Wrangler Technical Forum 11 01-13-2010 02:07 PM
need help. BL install, fuel filler neck. tim95jgc TJ Wrangler Technical Forum 3 05-17-2009 04:31 PM
Help with Fuel Filler neck after 1.25" BL! jrb470 TJ Wrangler Technical Forum 9 02-21-2009 05:38 PM
welding on the filler neck.. drenmaster j TJ Wrangler Technical Forum 10 11-24-2005 01:48 AM
