Gas Cap and Fault Codes - JeepForum.com
post #1 of 12 Old 05-13-2008, 04:07 PM Thread Starter
AferVentus
Hi,
On my '06 TJL, I had a check engine light, so I went through the 'push the odometer button while turning on' thing and it said no faults.
I then took it to the dealer and they said it was a loose gas cap. (I took the cap off before and put it back on to make sure but it was still the gas cap.)
My question is this: Why didn't the code show up in the odometer through the procedure that I used?
Thanks in advance.
AferVentus is offline
post #2 of 12 Old 05-13-2008, 06:07 PM
Rubikahn
Rubikahn's Avatar
Has the CEL cleared? Was this the first time it happened? If not you may want to go back to dealer with this TSB number.
Make : JEEP Model : WRANGLER Year : 2006
Manufacturer : DAIMLERCHRYSLER CORPORATION
Service Bulletin Number : 1400106 Date of Bulletin : JAN 21, 2006
NHTSA Item Number : 10019243
Component : FUEL SYSTEM, OTHER
Summary :
LOOSE FUEL CAP MESSAGE OR MALFUNCTION INDICATOR LAMP ILLUMINATION FOR DIAGNOSTIC TROUBLE CODE P0457 - EVAP SYSTEM - LOOSE FUEL CAP. *TT
Rubikahn is offline
post #3 of 12 Old 05-14-2008, 03:22 PM Thread Starter
AferVentus
No, this is the first time it happened, and the dealer found the code P0457 and cleared it.
It just seems odd that it wouldn't show up in the dash for the consumer. (Me)
post #4 of 12 Old 05-14-2008, 03:40 PM
03silversport
My 03 just threw the same code a month ago. But instead, of the odometer button key trick, i rotated the key on-off, on-off, on-off, on, and the jeep showed the same code you have described. i went to the station, put some gas in the jeep and made sure the cap was on tight, started it back up and no more error code. (i went to autozone with the code and they printed out what it could be, therefore i knew it was the gas cap issue)
03silversport is offline
post #5 of 12 Old 05-14-2008, 03:51 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Yep, try the key trick next time.
Wheelin98TJ is offline
post #6 of 12 Old 05-18-2008, 09:49 PM Thread Starter
AferVentus
Okay, it's doing it again. (Probably going to make them replace the locking cap, because it is still under warranty.)
Now is this from ACC to On or all the way off?
post #7 of 12 Old 05-18-2008, 09:56 PM
Havoc
2015 JK Wrangler
off-on-off-on-off-on
watch odo meter
p0457 done ?
Havoc is offline
post #8 of 12 Old 05-18-2008, 10:06 PM
M2LJ
For one, you were doing the wrong procedure for getting an error code...
Turning the ignition on-off-on-off-on rapidly will cause any fault codes will display in the odometer (if none, will read 'done').
Depressing odometer reset button while turning on the ignition will initiate the instrument cluster checklist sequence. It has nothing to do with OBD codes, but it is pretty entertaining to watch!
By the way, did you replace the stock cap with a locking one? If so, and you didn't get the right cap (don't buy a generic locking cap, there is a specific one needed but you can get it at most auto parts stores), it will cause the code to throw. Trust me, I learned this the hard way...
Cheers! M2
M2LJ is offline
post #9 of 12 Old 05-19-2008, 07:56 AM
jwpmel
You wouldnt happen to know that part # for that specific gas cap would you.
jwpmel is offline
post #10 of 12 Old 05-19-2008, 08:27 AM
blackattak
I'd like the part # for the proper locking cap as well as I had this issue before as well.
blackattak is offline
post #11 of 12 Old 05-19-2008, 04:02 PM
M2LJ
The Mopar one is M05278655AA, but if you go to any large auto parts store, it will have a listing. Mine is a Stant, and I think the model number is 10508. It also fits on a Toyota..
But do not buy a generic one from WalMart, as it will throw codes!
Cheers! M2
M2LJ is offline
post #12 of 12 Old 05-19-2008, 04:35 PM Thread Starter
AferVentus
I got this when the vehicle was new and now it is acting up. (It is from Mopar.)
Yes, the P0457 gas cap code showed up. By the way, what's the warranty on Mopar Parts? (I still have regular warranty.)
Thanks for your help everyone.
fault codes BadApple1403 YJ Wrangler Technical Forum 6 06-20-2009 01:21 PM
Fault Codes? SEMO 95 YJ YJ Wrangler Technical Forum 0 02-14-2008 05:41 PM
95 yj 2.5l fault codes? noturaveragehak YJ Wrangler Technical Forum 3 09-06-2007 10:29 PM
fault codes ember YJ Wrangler Technical Forum 7 03-21-2006 03:39 PM
Fault codes? CosmicCreeper YJ Wrangler Technical Forum 10 01-22-2005 10:37 AM
