Fuse blows when put into reverse - JeepForum.com
post #1 of 6 Old 07-22-2013, 05:14 PM Thread Starter
Joemon11
99 Wrangler 2.5 manual. Wouldn't start, would crank, but not turn over. Replaced fuse # 20 in the PDC under the hood, as it was blown. This fixed the problem, Jeep turned over fine. BUT... when I put in reverse and clutch engaged then it died and the same fuse was blown again. Replaced the fuse and started fine, had no problems engaging clutch in all the forward gears. Why did the fuse blow when put into reverse, where do I start? Any and all help is appreciated.
Joemon11 is offline
post #2 of 6 Old 07-22-2013, 05:46 PM
KaiserJeep
There is an electrical short to ground in the backup lights. It is probably near the lights but could be anywhere between the fuse and the lights. There is a backup switch in the transmission that activates the lights.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline
post #3 of 6 Old 07-22-2013, 06:25 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Aren't the backup lights powered off the Fuse Block and not the PDC?...
Knuckelhead is offline
post #4 of 6 Old 07-23-2013, 06:34 AM
steveinmedford
steveinmedford's Avatar
2014 KL Cherokee
Check the bulb sockets. One of mine fried and melted the base. Is it wet under the lens?
Steveinmedford
2014 KL, Cherokee Latitude, 2.4, auto
steveinmedford is offline
post #5 of 6 Old 07-23-2013, 06:41 AM
BYuen
BYuen's Avatar
X2 on the bulb sockets. Happened to mine before and has to replace it.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #6 of 6 Old 07-23-2013, 11:48 AM
Jonny Jeep
Jonny Jeep's Avatar
Fuse 20 is the IOD fuse. It supplies power to the courtesy and under hood lamps, radio and cluster memory and the OBDII connector under the dash. It has nothing to do with either the reverse lamps or the running of the Jeep.
There may be a chafed or trapped wiring harness somewhere that is grounding out to the body/chassis or to other circuits, or an over heated section of loom where the conductors are touching. On it's own there's no way that fuse will stop the engine starting or running.
Jonny Jeep is offline
