Quantcast Fumoto engine oil drain valve - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Fumoto engine oil drain valve
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 02-16-2007, 12:08 PM   #1
barry1me
Has anyone ever bought one of these Fumoto drain plug valve write up? Seemed like a pretty good idea, I have a skid plate under my oil pan and its a pain to change the oil.
Sport TJ build
everything below has a hyperlink to the install/review
Rubicon Express Long Arm
D30 Alloy axle shafts with Alloy U joints
D30 Powertrax no slip locker
Skid row skids engine- gas tank - radiator- steering box
Expidition one trail series rear bumper and carrier
Edge Trail jammer install/review
Bestop Trailmax Aqua seat
Bestop Super top
Before you ask about a product in the Technical forums check out the product review section!
barry1me is offline   Reply With Quote
Old 02-16-2007, 12:09 PM   #2
Rocky529
Jeep
Rocky529's Avatar
I have it and like it a lot. It does take longer to drain, but I usually rotate the tires when it is draining. Works great for about a year now.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 02-16-2007, 12:32 PM   #3
BluesMan
I was looking at buying something like this. I made a skid plate, and while I can undo the drain plug just fine, at the end of the drain cycle it runs onto the skid and makes a big mess.
However from the pictures, it looks like this sticks down further and may catch on rocks and such. My skid fits only 1/8-1/4 inch below the pan.
Any input from someone that has one on how far down it projects?
thanks
BluesMan is offline   Reply With Quote
Old 02-16-2007, 12:40 PM   #4
claytonandson
claytonandson's Avatar
have had one on my ford truck for years.good item. i was thinking of putting one on the tj,but do not have any skids. not sure if the offroading i do would have the thing catch on something.
yellow jeep club #343
IAFF /FF's OF WASH. D.C. EMERALD SOCIETY/CHARLES COUNTY RESCUE SQUAD 51
claytonandson is offline   Reply With Quote
Old 02-16-2007, 12:42 PM   #5
erickpl
Don't use a fumoto unless you have engine/oil pan protection.
It doesn't really hang down any lower than my oil pan. I use tubing from Lowe's to drain it directly into the pan w/o getting anything on the skid (until I remove the filter).
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline   Reply With Quote
Old 02-16-2007, 12:45 PM   #6
Jeepin' Rock Cl
I've had mine for 5 years now. No problems.
Jeepin' Rock Cl is offline   Reply With Quote
Old 02-16-2007, 12:47 PM   #7
UTWeezul
I have one but didn't really like it so I went back to the normal drain plug. The skid gets messy when removing the filter anyways.
Enjoy life to the fullest each and every day!
http://www.midsouthjeeps.com/
UTWeezul is offline   Reply With Quote
Old 02-16-2007, 12:52 PM   #8
5artist5
5artist5's Avatar
1972 CJ5
I was thinking that one of those remote oil filter kits could save the oil on the skidplate mess?
Anyone try this?
KI6RIC
72 CJ5 258-3spd d30-d20-d44
Originally Posted by Bsktbll109 View Post
Does your rearend guy do gears?
5artist5 is offline   Reply With Quote
Old 02-16-2007, 12:58 PM   #9
barry1me
Anyone try this?
X2 I want to know...thats the biggest pain for me when changing the oil.
Sport TJ build
Bestop Super top
Old 02-16-2007, 01:51 PM   #10
ptowntj
I agree...a remote oil filter would help.
04TJ 3.5 RE Extreme Duty Long Arm, ARB F&R, 4:88's, Cromo shafts, 35 MTRS, Rokmen Armor.
TJ's gone. See you on the trail in my Toyota :).
ptowntj is offline   Reply With Quote
Old 02-16-2007, 01:54 PM   #11
mdm
Farm Wheeler
There is also the Fram Sure Drain which is somewhat similar but less than half the cost.
mdm is offline   Reply With Quote
Old 02-16-2007, 02:04 PM   #12
kingvm
kingvm's Avatar
2005 WK
I was considering one of them also, because of the problem with the skid plate. I decided to just drop the skid each oil change since the skid could usually use a few whacks with a big hammer to make it flatter by then anyway....
05 Grand Cherokee Limited, 5.7 hemi, quadradrive II, Nav, 3" lift, JK Rubi wheels/tires, 4xGuard skids
kingvm is offline   Reply With Quote
Old 02-16-2007, 02:07 PM   #13
yellj
It's only $25 bucks, to me it's jsut plain quicker, get the one with the nipple, you can attach a piece of 3/8" ID tube to the nipple open it up and it goes right into your container, no need for an oil pan, I just save my old jugs and drop it off at the local Midas. Did I say jugs and nipple? , by the time you would drop your engine skid, you will be done with the chage, 1/4" skids don't need any whacks
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
www.midatlanticjeepers.com
yellj is offline   Reply With Quote
Old 02-16-2007, 02:29 PM   #14
UTWeezul
I've heard of people using a plastic grocery bag and removing the filter from the top and letting the filter and oil just fall into it. I'm going to try this next time around and see if it helps at all.
Old 02-16-2007, 02:46 PM   #15
5artist5
5artist5's Avatar
1972 CJ5
Does anyone know why this kit that says it's for 81-03s would not fit an 06 TJ?
http://www.4wd.com/productdetails.aspx?pid=10695
KI6RIC
Glock Forum
CALL 1-800-274-2460
