#1 | |
Fumoto Engine Oil Drain Valve
http://www.fumotovalve.com/ Does anyone here have this on their Jeep?
[B]Waiting patiently for the 2006 Sport I'm having built![/B] The older I get the less I care what people think! You know your life sucks when the date on your condoms expire. Feel free to check out my Night Terrors message forum at [url]www.nighterrors.com[/url]. |
#2 |
#3 | |
#4 |
It'd be nice under a Skid Row or other engine skid where it's hard to reach and well protected, but under something like my close-fitting Tera skid I don't imagine it'd last long on the rocks... even my stock drain plug has a flat spot where one of the corners has been ground off.
2001 TJ Sport 2" coil lift, 31" TrXus, swapped in 3.73s, ORFab cage, Aussie front locker, A to Z Fab rocker skids, JeepMedic Oil Pan Skid, JeepMedic LCA skids, Alloy USA D30 Seals, Warn Diff Skids, Cobra 75wx CB, Jeeperman prototype front bumper, 9.5ti, custom rear bumper, Rokmen frame tie-in kit. |
#5 |
I have a different one. It has no valve on it so it's not as bulky, I got it at autozone. It has a tube that pushes into the plug and allows it to open. I just keep the tube in the glove box.
#6 |
what Rusty the Scoob said. i like mine but i also have a skidrow skid
#7 |
I have one and like it alot. I probably wouldn't recommend it unless its covered by a skid plate.
#8 |
Would it be safe without a skid plate if a person didn't do any off-roading?
#9 |
Have one similar, I think it's made by Fram. Replaces the drain plug with an internal spring valve. You screw a short section of plastic line onto it that opens the internal valve. Has a cap to cover the threads when not in use. I don't think it sticks down as far as the fumoto.
http://store.summitracing.com/default.asp?target=egnsearch.asp&N=115+400383+3052 62&autoview=sku Heres a link for a better idea. I think I found mine at Wally world or autozone.
Not all pain is gain. _____________________________________________ '03 TJ X, silver - 4.0 auto, 4" Skyjacker, 33's, KC's Kenwood/Polk/Alpine '67 Jeep M-715 to begin construction or destruction depending on the day |
#10 |
Have it, love it and as stated be sure to have a skid plate.
#11 |
Do it right or not at all
![]() Join Date: Jan 2003
I installed a Fumoto valve and now consider it to have been a waste of money. First, it has such a small diameter drain hole and tube that it takes too long to drain the crank case.
Second, it doesn't really cure the messiest part of the oil change process which is removing the old oil filter. I'm no longer a fan of the Fumoto valve, it just doesn't help all that much... and it sure slows the draining process way down. I start the drain process and then start on the oil filter change. By the time I have completed the oil filter swap process, the crank case is still not done draining through that Fumoto valve. ![]()
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#12 |
Accident Prone Bonehead
Getting messy is half the fun......... Besides, not a fan of things hanging down any farther than they have to,....unless you have a skid plate.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top. Classic4x4 tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud. Hermiston, ORL AtoZ Where Zach makes me toys! Stu-Offroad, because I don't have a clue, but Stu does! |
#13 |
If you have an engine skid it certainly helps from oil collecting in it when you change the oil if you attach a piece of tubing to the nipple (3/8"I believe). It is a little slow, but I set it up with the tube draining into an old oil container, then check a few things to see if they loosened up, may add an extra 5-10 minutes, I just use that as inspection time underneath. With the Medic skid, it would be a real PITA without, it is above the skid so not subject to rocks.
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416 www.midatlanticjeepers.com |
#14 |
Is the drain tube included? If not, what diameter tube do you need? Thanks!
Current Ride: 97 TJ Sport 5spd Check profile to see the mods! Other mods to come... My crazy dog! Clicky You've gotta love days like this at work! Yes, I threw it...Clicky |
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
