full width. - Page 2 - JeepForum.com
post #16 of 19 Old 07-11-2010, 08:40 AM
Border Dave
Got Sand?
Border Dave's Avatar
Originally Posted by asknight View Post
He's going to have an extremely short rear driveshaft with that C6.
I hope the pinion angle is good and not much articulation is hoped for.
Couldn't he use a Dana 20 transfer case? If so, wouldn't that be quite a bit shorter than the NP231?
edit: The OP has an Unlimited. I would think he would be fine with the NP231.
Border Dave is online now
post #17 of 19 Old 07-11-2010, 11:09 AM
jagular7
Swap bodies. Keep the frame, running driveline, and axles all under the Ford frame. Put your Jeep body on that. Trim the rear wells for the wheelbase. Sell off the Bronco body for parts for other and probably make back your initial cost.
The Ford frame is much stiffer. The driveline can handle itself as proven it is still running together. Modify the stock radius arms for articulation with extending them as well as putting a rod end on the end. Have fun with it.
The wheelbase of the Bronco is in line with a CJ6/8 length.
Mike
Jagular
Lnxa, KS
97 TJ SE lifted, locked and rubbered for fun
94 YJ SE stock, 225s, Trail Tested
jagular7 is offline
post #18 of 19 Old 07-11-2010, 02:26 PM Thread Starter
remery829
i have the same wheelbase as a cj8 and the nv241 t case, but i don't know if i'm going this route anymore after finding out about the radius arm d44. it would take to much work to put it under the jeep. i'll probably just wait around until a f250 comes up for sale around here for cheap
Ryan
vvvthis is what they don't tell you about LCGvvv
...I went with the lcg method but its never ending be because once you fix one thing something else breaks or needs upgrading...
SUPPORT OUR TROOPS
remery829 is offline
post #19 of 19 Old 07-11-2010, 04:29 PM
goldswim5
If you could find a Supercab F150 they have the leaf sprung HPD44 in the front as well. That's what mine is.
2005 Wrangler Unlimited
6 speed, hard top, bone stock
goldswim5 is offline
bronco , full width , tj , wrangler , swap , axle , motor , engine
TJ--axels--full width vs. stock width smithcon TJ Wrangler Technical Forum 2 06-05-2010 05:19 PM
Full width to full width (9 inch to dana 60) hmmhoyhoy YJ Wrangler Technical Forum 0 08-01-2009 03:45 PM
Full Width help please smeshey YJ Wrangler Technical Forum 24 07-19-2007 07:56 AM
help on going full width!!! jipjip YJ Wrangler Technical Forum 3 10-09-2006 08:26 AM
