full width. - JeepForum.com
post #1 of 19 Old 07-09-2010, 11:27 PM Thread Starter
remery829
full width.
sooooo i have an opportunity to pick up a 78 bronco for a ridiculously good price. has a 9 inch in the rear and a hp44 in the front. also has a strong running 400 mated to a c6. and he has a 351w that he'll throw in that ran when he took it out, but it needs a good tune up.
plans are to build the axles slowly until this winter and throw them in around the end of the year.
i'm wondering if it would be worth it to rebuild and put in the 351 and c6 also, or 400 and c6, or to just sell the motors and tranny, then scrap out the rest of the bronco
Ryan
vvvthis is what they don't tell you about LCGvvv
...I went with the lcg method but its never ending be because once you fix one thing something else breaks or needs upgrading...
SUPPORT OUR TROOPS
remery829 is offline
post #2 of 19 Old 07-10-2010, 12:26 AM
bruteboy
the c6 trans from the 400M will not bolt up to a 351WINDSOR.
if it is a 351M,then it will.
the c6 is a 3 speed auto and will limit top speed.
it may have a np205 or a np203 t-case.
the 351/400M is large and heavy,as is the c6,and may not fit too well into the tj.
the wheel bolt pattern on the bronco diffs is 5on5.5 and will require new wheels.
bruteboy is offline
post #3 of 19 Old 07-10-2010, 12:33 AM Thread Starter
remery829
it is a 351m. my mistake.
i know i will need new wheels, that isn't an issue
one of the main things i'm wondering about is how a low pinion 9 inch will do. i do have a longer wheel base which helps, and want to avoid having to use limiting straps, but will use them rather than paying for a hp 3rd member
Ryan
SUPPORT OUR TROOPS
post #4 of 19 Old 07-10-2010, 12:43 AM
bddisi
Doooooooo it. At least the axles...
Scorpion-Offroad-Concepts
bddisi is offline
post #5 of 19 Old 07-10-2010, 12:59 AM Thread Starter
remery829
the axles will go in. oh they will. i'm figuring 39.5s will compliment them well, with chromo of coure
Ryan
SUPPORT OUR TROOPS
post #6 of 19 Old 07-10-2010, 01:25 AM
goldswim5
Since the front of the bronco is coil sprung and has radius arms, the arm mounts are cast into the axle. You'll have to build your brackets around that somehow, but that's the only problem I see. If I wasn't trying to rebuild my 78 F150 I'd be doing this same thing. May still end up doing it.
2005 Wrangler Unlimited
6 speed, hard top, bone stock
goldswim5 is offline
post #7 of 19 Old 07-10-2010, 01:32 AM Thread Starter
remery829
i was just going to cut them off and weld on new brackets....
Ryan
SUPPORT OUR TROOPS
post #8 of 19 Old 07-10-2010, 01:37 AM
MilitaryJK4455
2010 JK Wrangler
Why would you want that big of a motor on a 3 speed?
MilitaryJK4455 is offline
post #9 of 19 Old 07-10-2010, 02:03 AM Thread Starter
remery829
because picking up a different tranny would cost more than what i'm paying for it.
i'm leaning more towards keeping the 4.0l anyway. i only have 38k on it, and they're pretty much unstoppable engines
Ryan
SUPPORT OUR TROOPS
post #10 of 19 Old 07-10-2010, 02:07 AM
MilitaryJK4455
2010 JK Wrangler
Im not saying you in particular... Im asking for mechanical education... Why would you put a 3 speed tranny on a 400cu in motor?
post #11 of 19 Old 07-10-2010, 03:18 AM
asknight
Why not? How fast do you plan on going in a off-road configured Jeep? The C-6 will get it well past 120mph if the driver is brave enough.
asknight is offline
post #12 of 19 Old 07-10-2010, 03:19 AM
asknight
He's going to have an extremely short rear driveshaft with that C6.
I hope the pinion angle is good and not much articulation is hoped for.
asknight is offline
post #13 of 19 Old 07-10-2010, 03:20 AM
asknight
There's still a good many strip racers running the old GM Powerglide automatic. It's only a 2 speed.
asknight is offline
post #14 of 19 Old 07-10-2010, 03:34 AM
MilitaryJK4455
2010 JK Wrangler
Huh... Ok, I was just curious... That other guy said that it would limit top speed but hell 120mph is more of a top speed then I would want anyway.
post #15 of 19 Old 07-11-2010, 12:11 AM
goldswim5
Read around in this thread, it'll tell you all about the brackets on that axle. Specially the link unlimited04 posted.
http://www.jeepforum.com/forum/f9/ford-hp-d44-995050/
bronco , full width , tj , wrangler , swap , axle , motor , engine
TJ--axels--full width vs. stock width smithcon TJ Wrangler Technical Forum 2 06-05-2010 05:19 PM
Full width to full width (9 inch to dana 60) hmmhoyhoy YJ Wrangler Technical Forum 0 08-01-2009 03:45 PM
Full Width help please smeshey YJ Wrangler Technical Forum 24 07-19-2007 07:56 AM
help on going full width!!! jipjip YJ Wrangler Technical Forum 3 10-09-2006 08:26 AM
