Full Door Rattle - JeepForum.com
post #1 of 11 Old 07-09-2010, 06:46 AM Thread Starter
Rubikn65
Full Door Rattle
I've had my 03 Rubi for about 4 months now (had my YJ since '92 - lol) The Rubi has full doors - and since I took the hard top off - they really seem to rattle. Never heard anything with the top on and the half doors on my YJ are quiet. General question is whether this rattle is normal for the full doors with the top off? If not, any advice on tightening up the catches? Don't wanna pop the door panels, etc unless I know its gonna do some good. Thanks for any advice.
Rubikn65 is offline
post #2 of 11 Old 07-09-2010, 07:15 AM
Sundowner
Welcome to the forum!
The rattle is most certainly NOT normal...I run with full doors and the folding frames in place to hold a full-length bikini top on, and I noticed the same problem...turned out that it was just a loose latch. I've also heard of linkages loosening up inside. It could also be a hinge moving around on you. Check that everything's good and tight.
Sundowner is offline
post #3 of 11 Old 07-09-2010, 07:33 AM
Benderff
Benderff's Avatar
If you are not running door surrounds the doors usually rattle.
Benderff is offline
post #4 of 11 Old 07-09-2010, 07:42 AM
Sundowner
Why would someone run a full door and not keep the surround in place? Never occurred to me to do that. I guess that would make it rattle.
post #5 of 11 Old 07-09-2010, 07:53 AM
Roadrunner2
Not having door surrounds can cause the door rattle. If you only have a hard top you will need to buy the door surrounds. They are used with the soft tops. I bought mine on ebay for half price around $125.
2004 Rubicon
Roadrunner2 is offline
post #6 of 11 Old 07-09-2010, 07:57 AM Thread Starter
Rubikn65
Gotta be the door surrounds. Only have a hard top for the Rubi - and the yj only has a soft top with half doors - so never had the problem before. Thanks much for the help -
Rubikn65 is offline
post #7 of 11 Old 07-09-2010, 08:03 AM
Sundowner
Mine came with both tops and the bikini...makes sense. Never thought of it that way.
post #8 of 11 Old 07-09-2010, 08:17 AM
Benderff
Benderff's Avatar
IMO the better option is to pull the door off. I pull the doors and the top at the sometime.
Benderff is offline
post #9 of 11 Old 07-09-2010, 09:45 AM
vtx531
Mine have always rattled with no door surrounds. I have a factory hardtop and bestop supertop.
vtx531 is offline
post #10 of 11 Old 07-09-2010, 09:50 AM Thread Starter
Rubikn65
Doors off is a cool option- and thanks for the 1/2 door offer - but think I'm goin with the safari doors - was thinkin about gettin 'em anyway - door rattle just speeds up the process -
Rubikn65 is offline
post #11 of 11 Old 07-11-2010, 10:46 AM
heslep1
i have an annoying squeek on mine only when i have the doors on im about to go nuts
heslep1 is offline
tj , wrangler , rubicon , rattle , loose , full , door
Need to replace full steel door with light weight door LenC JK Wrangler Technical Forum 17 05-11-2010 04:18 PM
Questions about Half Door and Full Door Locking Mechanisms... atticus_ar TJ Wrangler Technical Forum 8 12-04-2009 01:26 PM
Full Door Rattle TJShadow TJ Wrangler Technical Forum 10 05-12-2009 12:11 PM
YJ full steel door... anyway to seal the gap left between rollbar and door ? intenseblu YJ Wrangler Technical Forum 6 06-11-2007 08:07 PM
Door Rattle - Full Steel - Loose? gette TJ Wrangler Technical Forum 6 09-22-2004 04:25 PM
