Fuel tank vent (2001) - JeepForum.com
post #1 of 1 Old 02-11-2012, 03:09 PM Thread Starter
defmornahan
1987 YJ Wrangler
Back in December I made the mistake of filling up with my dad's wet gas, had to drop the tank, pump it out, etc. A week or two later, I start getting the ole Check Engine light. Pull the code, medium leak from the evap system...okay. I got a new fuel line from the dealership, some new vent line, a new seal for the fuel pump assembly, and dropped the tank today. Lo and behold, the driver's side vent line fittings have ripped nearly off at both the fuel tank and at the Y-fitting where both vent lines join and connect to the engine bay.
Looking at the tank and looking around at NAPA, Quadratec, JC Whitney, I get the impression that the rollover valve is permanently attached to the tank and I can't replace it by itself. Rather than do that, since I don't really go wheeling much with this and I have a 1987 Wrangler that's intended for that purpose, I was planning to seal the driver's side rollover vent with JB Weld and just run a straight vapor line from the passenger side vent to the metal line running to the engine bay. Is there a terrible pressing reason not to do this? Can I replace just the rollover vent?
defmornahan is offline
fuel tank , vent , vent lines
Fuel Return going to Vent on 89 Tank racerx8413 YJ Wrangler Technical Forum 0 06-04-2010 12:39 PM
where do i get vent caps for my fuel tank? klone YJ Wrangler Technical Forum 4 03-31-2010 12:11 PM
Fuel Tank Vent Weller92YJ YJ Wrangler Technical Forum 3 10-07-2009 04:14 AM
Fuel Tank Vent Lines for a 2.5l JonD YJ Wrangler Technical Forum 2 03-26-2008 01:13 PM
Fuel Tank Vent Lines? JonD YJ Wrangler Technical Forum 4 09-26-2007 08:49 AM
